You can but it will feel slow na due to the low compression
I have a 4agze that iwant too put into my ke70 I am just going too run it NA I have the loom for it but no ecu and I have smallport loom and ecu, can I just use the smallport loom and ecu? too run the 4agze?
Why not just swap your 4agze for a smallport 4age>?
Because later down the track I will be turboing it, but just want too get it running na first
You'll save allot of $$$ if you just get it running turbo'd to begin with.
I have all the right manifolds and stuff too make it na till I can get all the turbo stuff, just wanna know I. Cam run it off the smallport loom
Yes you can, u might need to swap the cas for a dizzy tho.
