Results 1 to 10 of 13
Thread: 16v 4age not running when hot
    Apr 2014
    cooper
    nsw
    narara
    austraila
    Default 16v 4age not running when hot
    hey guys new to the 4age engine, need some advance
    I have a bigport silvertop the car drives fine when cold but lacking bottom end power (still has tvis)
    when it gets to right operating temp It backfires and has no acceleration.
    I have change coil and igniter unit, inlet and tvis gasket, throttle body gasket, tps, I set the ignition timing to 10 degrees advanced
    had a look at the dizzy and was a bit rusty so I cleaned all the points up ran a little bit better but still backfired and has no throttle response like its getting a gut load of air spark plugs are really rich.
    has anyone had this problem before or is it just me..... thanks for your help in advance
    Senior Member Dylan's Avatar
    Dylan
    What car is this in, is there a Check Engine light connected?
    Apr 2014
    cooper
    nsw
    narara
    austraila
    hey mate no engine light is connected its in a ke70
    Dylan
    Is the cold start injector still installed, able to disconnect and see if it changes?
    Apr 2014
    cooper
    nsw
    narara
    austraila
    still installed haven't disconnect it as of yet will give it a try bit late now, neighbours will have a fit haha
    Dylan
    Was the timing set with a jump wire on TE1 and E1?, also check if the timing changes when doing this
    Apr 2014
    cooper
    nsw
    narara
    austraila
    I unplug cold start injector didn't make a difference, I just replaced all the old dirty fuel and put new fuel in along with injector cleaner and also put a new fuel filter in.
    when the car is in neutral and you slowly bring the revs up and goes up smooth but if you flat to the floor it will bog down an backfire.
    Noooob
    Check your cam belt timing..
    Apr 2014
    cooper
    nsw
    narara
    austraila
    I ve checked cam belt timing its spot on
    Apr 2014
    cooper
    nsw
    narara
    austraila
    ive checked the cam belt timing and its spot on
  1. 16v 4age drving wen cold when hot coughs and miss fires HELP
    By COOPERMIDDLETON in forum Technical - Questions
    Last Post: 12th April 2014, 09:35 PM
  2. [NSW] 4AGE Bigport 16V Engine, Complete, Running, Rebuilt!
    By GOT-20V in forum Car Parts For Sale
    Last Post: 13th May 2013, 12:44 AM
  3. WTB: Complete 4age rwd running.16v or 20v
    By phat rolla in forum Cars or Parts Wanted
    Last Post: 31st January 2012, 11:10 PM
  4. Anyone running redline dcoe manifold on a 16v?
    By Deeken in forum Technical - Questions
    Last Post: 8th September 2011, 11:48 AM
  5. 7age running cold - changed thermostat and now its running hot
    By boh086 in forum Technical - Questions
    Last Post: 18th January 2011, 08:33 PM
Tags for this Thread
