Results 1 to 3 of 3
Thread: Small port flywheel with big port clutch
    Jun 2011
    bazz
    nsw
    sydney
    Default Small port flywheel with big port clutch
    Hi all. Want to put a smallport clutch on my bigport 4age. Will a bigport clutch fit or do I need a small port one.
    Noooob
    The small port clutch is 212 mm vs 200mm of the bigport. If you get a smallport flywheel and bolt it up it will work.
    If you tried to put a bigport clutch on a small port flywheel it also wouldn't work.
    West
    You need the 212mm flywheel, like Matt says.
    You will also find a compatible flywheel in a silvertop (7kg) a blacktop (6kg) and a smallport (9kg).
    They are all the 212mm setups you can use.
    4agzee flywheel is 220mm and the thing doesnt fit inside a t50.
  1. Throttle body small port to RWD big port manifold
    By grey_nomad in forum Technical - Questions
    Last Post: 6th June 2011, 08:22 PM
  2. Running a small port off a big port ecu and harness???
    By 7age ae86 in forum Technical - Questions
    Last Post: 19th May 2011, 09:29 PM
  3. small port and big port heads, 256 cam,16v rwd water stuff
    By dehney in forum Car Parts For Sale
    Last Post: 17th December 2009, 05:24 PM
  4. Replies: 2
    Last Post: 3rd January 2007, 08:52 AM
