Results 1 to 1 of 1
Thread: [nsw] ae86, ca18, high mount, f series, all the fruit
    Apr 2010
    Jamie
    Kiama
    Default [nsw] ae86, ca18, high mount, f series, all the fruit
    ae86
    Engineered, rego till 13-2-15
    Resprayed Seth black
    Jdm pin stripe dAsh 125xxxkms
    body km unknown
    Ma61 retrimmed seats
    Power windows
    Engine
    Ca-18det
    Forged pistons
    HKS/Garrett high mount GT3037s with .73 rear housing
    HKS high mount cast manifold
    HKS external waste gate
    Screamer pipe
    Custom inlet manifold
    Steel head gasket
    Arp bolts
    Oil cooler
    3inch exhaust under diff with one hotdog
    Fmic with 3imch piping
    Spitfire coil packs
    550cc injectors (not fitted was waiting for tune)
    Surge tank and bosch pump
    Battery in boot
    MicroTech lt8 ecu
    Alloy radiator twin thermos
    Custom catch can
    Suspension/brakes/wheels
    14x7 an 7.5 -4 rays with good tyres
    Bc gold coilovers
    White line panhard bar
    White line adjustable Rear sway (removed for more traction)
    New rear brakes incl.. Drums, shoes and wheel cylinders.
    Wilwood front set up incl.. calipers, slotted rotors, braided lines and pads.
    Drivetrain
    S13 box
    Exedy button clutch
    Custom tail shaft
    Locked F series diff 4:1 ratio (bearings a little noisy nothing major) has new oil.
    Needs tune idles rich and cold start is bit crappy only running 12psi
    With tune and 18psi should be well over 300hp at the wheels
    The bad. Was burning little oil I changed to a thicker grade and seemed to stop.
    Needs wheel alignment and balance (rhf rack end has slight movement).
    Clutch slipped a few times I have brand new Exedy button to go in when it goes.
    $12,000
    located illawara area nsw
    contact
  1. High mount 4age Manfiold with dump
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 29th July 2011, 01:26 AM
  2. Looking for High Mount 20v Turbo Manifold
    By PRIMRK in forum Technical - Questions
    Last Post: 17th September 2010, 01:24 AM
  3. High mount SR manifold (T3)
    By SR910 in forum Car Parts For Sale
    Last Post: 30th June 2008, 02:21 AM
  4. high mount turbo manifold
    By spillman in forum Cars or Parts Wanted
    Last Post: 2nd December 2007, 02:45 PM
