Results 1 to 5 of 5
Thread: 4age 20v blacktop into aus spec ae86
    Dec 2013
    jonathon
    New South Wales
    Green Valley
    Default 4age 20v blacktop into aus spec ae86
    Im currently in the process of doing the 20v swap for my ae86, though i have a few questions. If i want to run an aftermarket ecu, am i able to use the wiring harness out of an ae111 bzr which the 20v came out of?
    if possible can i use the ae111 bzr ecu and wiring harness?
    if i want to run coilpacks what is the process for being able to run coilpacks instead of the distributor ?
    thanks in advanced!
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    You need Coil on plug adapter plate and some coils like 1nz unless you mean to run a coil pack and leads?
    Dec 2013
    jonathon
    New South Wales
    Green Valley
    What would be the easiest option ?
    Mar 2013
    Mirko
    Coil pack l guess but really almost the same especially if your going aftermarket ECU then makes sense to do the conversion straight away. Speak to Sam from SQ Eng he has them or you could just but mine with adapter plate lol. Sorry shameless plug
    Moderator Sam-Q's Avatar
    Endeavour Hills
    If you want to run an aftermarket ecu you get the loom that comes with it and fit the plugs to it that suit what's on the engine. I have new coil plugs handy for $5 each.
  1. Aus spec grille, AE86.
    By lewy in forum Cars or Parts Wanted
    Last Post: 5th December 2013, 02:38 PM
  2. [AE86] Willy's 4AGE aus-spec AE86
    By slide86 in forum AE86 Owners Forums
    Last Post: 19th December 2005, 05:57 PM
