Results 1 to 8 of 8
Thread: smallport 272 cam 8.6mm. can I run temporarily on oem ecu?
    Jan 2014
    Duncan
    Queensland
    Toowoomba
    Default smallport 272 cam 8.6mm. can I run temporarily on oem ecu?
    I have a race coming up. my head is ported and polished and ready to go. But i am running out of time to get a aftermarket ecu and tuning done.
    Can i run it on oem ecu??
    i know it would idle like a pig.. I dont care.
    I'll idle at 2500 rpm if i have to.
    as long as it makes a bit better power where it counts??
    please help i want to know before i go doing something stupid.. like will it lean out and blow up?
    I'm running 268's on a stock ecu if that helps you any. It idles lumpy, but is otherwise fine.
    E-Famous (Remeber your roots)
    It will be OK, but it is really on the limit of what the stock ECU can handle.
    That being said I have seen plenty of people running them on a stock ECU.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Depends on the profile itself rather than the total duration, my cams are 290 degree's total and 8.4mm lift and run fine on the standard MAP computer.
    let us know how u go in your class
    Jan 2014
    Duncan
    Queensland
    Toowoomba
    Took out first at Gatton sprints on street tyres with bouncing front shocks and dud brakes. Have race tyres, new shocks, hd swaybar big brakes and hopefully a few more ponies with the head and cams.. Hoping for another first
    Haha, well done.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Yeah, nice work. I run TRD 272 7.5mm in mine and is daily driven on stock ecu. Rough and fun.
  1. 4age camtech 272 8.6mm bucket under shim conversion.. or not?
    By crunk81us in forum Technical - Questions
    Last Post: 22nd January 2014, 01:33 PM
  2. Replies: 3
    Last Post: 24th April 2012, 12:06 AM
  3. Replies: 7
    Last Post: 4th August 2011, 10:23 PM
  4. 277º 8.6mm Lift Cams & Adjustable Cam Gears
    By Mitchee in forum Car Parts For Sale
    Last Post: 15th November 2007, 11:22 AM
