Results 1 to 8 of 8
Thread: WTS Race prepped 4age 304 cams 13.5:1 comp arp etc.
    Senior Member MoNsTaR's Avatar
    Jul 2009
    Richmond
    Default WTS Race prepped 4age 304 cams 13.5:1 comp arp etc.
    hey guys,
    due to financial issues and other reasons I've had to part ways with my motor and 4age kit for ke70.
    4age:
    tomie power cams 304 duration 11mm lift.
    custom 3mm over sized solid lifter conversion.
    head ported.
    Bigport head.
    standard sized valves.
    supertec valve springs.
    wiesco FA spec pistons and rings.
    Black top block.
    Black top rods.
    ARP Bolts threw out the whole motor.
    TRD .5mm headgasket.
    Gates Racing timing Belt.
    Everything balanced,
    fucking rad paintjob.
    everything was chemically cleaned before machining
    im sure theres more I've missed.
    it made 105 kw at 6000 rpm, it was designed to rev to 10k. had issues with having too small sized carbys.
    the motor neads 45mm webbers with 40mm chokes or ITBs and larger injectors.
    the injector holes are currently blocked only by welsch plugs so they are easily removed.
    comes with heaps of spares!
    carby kit consists of:
    Kehin CVK carbies 41mm
    Manifold to suite bigport head
    4K Distributor + leads modifies to suite 4age.
    facet fuel pump.
    Holly Bypass Regulator.
    Bosh GT40.
    conversion gear consists of:
    T50 (average condition)
    ae86 gearbox mount.
    shifter.
    heat wrapped headers and exhaust.
    tailshaft.
    also have Borgy diff.
    spare axles and diff center.
    tacho dash
    For the WHOLE lot. so pretty much the whole driveline and conversion kit.
    $4500.
    the engine $3500
    Carby setup $400
    conversion gear $600
    borgy with spare axles and diff $250
    tacho dash $50
    I would prefer to sell everything together.
    EVERYTHING AT THIS STAGE IS STILL IN THE CAR!
    so if you would like a demonstration or a test run/ startup. you can do so.
    Quote Originally Posted by sam2306 View Post
    its not a gang till we have stickers
    Quote Originally Posted by *E7* View Post
    rust is lighter than carbon fibre
    Jul 2009
    Richmond
    bumpadump
    Veteran drift kid's Avatar
    Glossodia
    Dat paintjob doe
    Terry
    Ipswich
    what crank is in it?
    Jul 2009
    Richmond
    black top 20v crank
    Jesse
    Auckland
    North Shore
    New Zealand
    Still got the tacho dash?
    Jul 2009
    Richmond
    yes i do
    Jul 2009
    Richmond
    Engine and gearbox sold!!!
  1. Hks and trd cams. Microtech for 4age. Arp bolts and studs
    By timpy in forum Car Parts For Sale
    Last Post: 20th August 2013, 12:14 AM
  2. 4age cams, quads, arp hks trd t3
    Last Post: 7th January 2013, 09:21 PM
  3. [NSW] HKS 288/304 Cam - 4AGE 16V
    By JDMWheels in forum Car Parts For Sale
    Last Post: 3rd January 2013, 12:05 PM
  4. Feeler: HKS cams 304 deg. 4age 16v
    By haydenz in forum Car Parts For Sale
    Last Post: 9th March 2009, 09:06 PM
