Results 1 to 9 of 9
Thread: Run down of diff specs?
    Senior Member stouty's Avatar
    Leigh
    Forster
    Default Run down of diff specs?
    Hi
    I am after some information regarding Tarago and Litace diffs. Looking for model and years they where available also axle size and spline number. I have spent an hour or so looking for the info in s and t series differentials and f series diffs. Couldn't find axle size and spline number.
    Thanks
    Leigh
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    Mt Macedon
    I can't remember the measurement details off the top of my head, but:
    - S and small T axles have identical splines. Maybe 23 spline and 24mm diameter
    - Large T and E axles have the same spline count (also same as S and small T) and measure at the same diameter, but are NOT interchangeable. Maybe 23 spline and 25mm diameter (25.3 in fact).
    - F is bigger.
    There was a famous photo that floated around back in the day showing the diameter of a small and a big T spline being measured. OK,
    Eddie
    As Hen has stated, zenki t-series is 24mm, kouki is 25mm give or take. F-series have 27 spline 28mm axles. G series is 30 spline 33mm (or there abouts).
    YR22 tarago is F-series but are wider than ae86 width at around 1470. The only stock width f-series is the mx13/23 which are ridiculously rare now. The final overall width will be determined by the brake setup you put on the ends.
    Leigh
    Forster
    Thanks for the info guys much appreciated
    Grip TE72
    West
    The mx12/23 diffs are actually 6mm wider than ae86 stock diffs. They arent exactly the same width. Nothing else comes close to the width of the ae86 diff by anywhere near as much though. From memory the mx13 diff is 1416mm and the AE86/T18 diffs are 1410. Celica T being 1430. I could be wrong but thats what my memory tells me.
    Mt Macedon
    If you're going F don't be weak. MS112 diff is F, good discs, massive wheel bearings, big track increase and 5x114.3
    Leigh
    Forster
    What year model crown is the MS112? Also I have recently been told the feroza run hilux duffs has anyone else heard this?
    Grip TE72
    Mt Macedon
    Is my best estimate of dates.
    Leigh
    Forster
    Anyone heard about Ferozas running toyota hilux diffs?
    Grip TE72
  1. Ke55 specs ? help
    By Faze in forum Technical - Questions
    Last Post: 12th March 2013, 06:12 PM
  2. help with torque specs
    By bones in forum Technical - Questions
    Last Post: 5th September 2010, 04:33 PM
  3. Specs
    By benbertucci in forum Technical - Questions
    Last Post: 24th June 2009, 03:43 PM
  4. headbolt specs
    By dustyae86 in forum Technical - Questions
    Last Post: 18th September 2007, 02:39 PM
  5. st141 corona diff qns? specs?
    By killer ke70 in forum Technical - Questions
    Last Post: 21st March 2007, 08:09 PM
