Swap the spark plugs between cylinders if you haven't already to see if the problem moves cylinders. Could be a cracked plug, but unlikely.
I'd also swap the injectors to see if the lazy cylinder changes. If you have spark on the lead , then it should transfer into the cylinder, which leads me to think it would be a fueling issue... You'd expect the problem cylinder plug to be dry and definitely not black.
When you are timing these and any 4age engines, make sure you bridge the terminals in the diagnostic box. T1 & E1.
As for over fueling, that is another issue that I'm not sure what the problem would be. Measuring the fuel pressure might help as I've seen quite a few of these fuel pressure regulators fail.
