Wrecking ke70
located Sydney Northern beaches. Willing to ship any where at buyers expense.
everything is Neg.
1984 ke70 shell, has damage too RHF (fixable by pulling or rebuilding w/tube) also needs right front guard, head lights.
Shell is seam welded
Has custom upper rad support and crash bar that fits perfectly behind beaver panel
Big trans tunnel
Sheet metal rear fire wall
boot cut out for fuel cell
Big metal rear flares (one has slight damage) tubbed inner (needs bit of sealant maybe)
Full cage, side intrusion bars, harness bar
Black, paints seen better days in parts
Doors have some fancy stuff too. $1000
Te72 pedal box + 1yr old clutch master $150
Sigma LCAs boxed and rose jointed. Used $100
T3 P/S knuckles. Not drifted on but modded for inner steering arm hole ony, cannot use outer hole. $150
Ae86 GTV steering rack (quicker ratio & nonP/S) has AJPS longer/stronger tie rods & ends (one has dicey boot) SOLD
Ae86 castor rods. Real good adjustable, except cut for sway bar single hole ($50)
Ae86 custom coilovers, with cusco adjustable tops. Well made, work well but not pretty. 8kg springs. $400
ae71 front cross member. Bottom is Scraped heavily $50
ke70 steering column. No barrel or steering lock. Unis good. $50
AJPS large size roll center adjusters. Good. SOLD
G series hilux diff. To suite ae86. 4x114 stud pattern. Converted to r31 disc & Vs commodore twin caliper with custom brackets. Has all brake lines. Diff has backlash, either needs rebuild or just drive it. Mounts have been broken and repaired (drift car) could do with being redone or again just use it. Includes everything down too pads. SOLD
CNC handbrake too suite. New master and lever. Can include lines $200
S13 - hilux one piece tail shaft, for ke70. 70's ford unis (strong). Professionally made $300
Trd blue rear springs, 7kg. Cut. $50
AJPS pan hard rod. Good nick $150
2x Black Super lights 15x10 -12 with Falken semi-slicks. 80% remaining.$500
4x Black super lights 15x10 -26 with Duro & Khumo tyres 70% $800
Ae86 Willwood kit, v-good condition. Includes everything to put staight on you ae86 struts. Hubs bearings pads lines everything. $800
Interested in your fc rx7 bits.
txt msg josh, zero four16806 179.
Need things gone, make an offer
