Results 1 to 7 of 7
Thread: TRD Carbon Airbox and Ramtubes Suit 3S Beams
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Default TRD Carbon Airbox and Ramtubes Suit 3S Beams
    For Sale - TRD Carbon Airbox and IMEC short ramtubes to suit 3S Beams motor.
    Super rare, make your engine bay look a little bit fancy. Has been drilled to suit 3sge throttle spacing, but will fit 20v 4age with a little bit of modification. 4" inlet.
    Chasing $700 including postage for both airbox and ramtubes. Located in SA
    Andy
    Senior Member ae86 drifter's Avatar
    Pete
    wats involved with making it fit for 20v?
    ROYAL GARAGE NEWCASTLE
    Andy
    Adelaide Hills
    Would probably need the holes either fibreglassed back up or ground out slightly to suit the narrower spacing, should fit fine otherwise
    Andy
    Veteran AJPS's Avatar
    Lonsdale
    what you changing to?
    West
    How much wider is the beams spacing? It might be perfect for my 2az itb setup that is 10mm wider each space between.
    Andy
    Adelaide Hills
    PM'd
    Andy
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    Still available?
  1. W5* Gearbox to 3S Beams Clutch Options
    By Clasyk in forum Technical - Questions
    Last Post: 12th November 2013, 08:50 PM
  2. TRD quad throttle set up suit BEAMS
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 19th January 2013, 10:25 AM
  3. TRD inlet suit vvti or no vvti BEAMS
    Last Post: 29th May 2011, 04:33 PM
  4. 3S-GE Beams Engine Package.
    By nomis in forum Car Parts For Sale
    Last Post: 6th January 2011, 12:32 AM
  5. 3s beams engine conversion 98 altezza
    By albertos in forum Car Parts For Sale
    Last Post: 30th August 2008, 12:39 AM
