Results 1 to 2 of 2
Thread: 4age small port dcoe inlet manifold plus 4age heads
    Glenn
    North Ringwood
    Default 4age small port dcoe inlet manifold plus 4age heads
    have 1 small port dcoe carb inlet for 4age motor 150 plus post
    also have 3 bigport 4age heads after 150 each for these
    3 gear sticks to suit t50 box 50 each
    4age backing plates 20 each
    4age motor to gear box stays 30 a set
    1 block with main caps 100
    1 block with crank and sump 150
    block with pistons rods and crank and sump 200 ae86 disc brake axles early 150 the pair
    disc brake backing plates and calipers to suit ae86 rear set up 100
    rwd exhaust header factory 150 each
    rwd alternator bracket 150 plus heaps of other stuff
    Tobias
    Tas
    South of Hobart
    Would you be able to post 2 sets of the motor to gearbox stays and the rwd alternator bracket to Tassie at my cost?
  1. WTB URGENT- Small port inlet manifold cut and shut
    By willa in forum Cars or Parts Wanted
    Last Post: 31st May 2011, 07:41 AM
  2. Rwd small port inlet manifold
    By ae86 slide in forum Cars or Parts Wanted
    Last Post: 29th March 2011, 09:42 PM
  3. Wtb rwd inlet manifold big port inlet manifold
    By armc89 in forum Cars or Parts Wanted
    Last Post: 19th November 2010, 12:09 PM
  4. small port and big port heads, 256 cam,16v rwd water stuff
    By dehney in forum Car Parts For Sale
    Last Post: 17th December 2009, 05:24 PM
  5. Wanted- Small port fwd inlet Manifold- Syd
    By SIM355 in forum Cars or Parts Wanted
    Last Post: 4th January 2008, 05:10 PM
