Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: rb25 into ke70
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default rb25 into ke70
    i wanna hav a stupidly quick sleeper im thinkin rb25 is around the same price as an sr turbo
    and could be alot funner 2
    how much of the fire wall an i going 2 hav 2 cut out and will it clash with the brake/clutch master cylinder?
    custom mounts
    tailshaft
    diff
    ecu
    should b easy enough
    Jonathan
    Quick, lock the thread!
    Veteran bigm's Avatar
    Gold Coast
    RB25 is more expensive than SR
    it weighs more - car would handle like poo
    its a very long motor- would have to hack away at the firewall, not be able to be registered either
    not easy by any means.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    SR20's have been proven to make as much or even more power with less money spent on them.. SR all the way!
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    put a 4ac in it.... warp speed kinda shit
    MY JZX83 (clicky)
    E-Famous (Remeber your roots)
    Not worth the effort.
    Veteran Konakid's Avatar
    Henry
    Eastern
    For the same amount of money it would cost to make it all work, you could buy an r31 and do a 25 conversion to that which might actually still handle and be able to control the power.
    Gone
    Joel
    Picton
    AGREED!.. the RB25 although have the extra 500cc over the SR, doesnt give it the extra power, their long, bulky engines mated with a big bulky gearbox.
    their nearly half as long again as an SR and your shifter positing would be in the back seat.
    if u want something stupidly quick - for street use.. throw a set of pistons and cams in an SR with an ECU and turbo.. 3037 or ring the neck of a 2871R and u will have an easy 250+ KW at the treads... now in a car like a 70 .. i dno about u but get some decent tyre/wheel/suspension/Diff combo up back and it will hammer! go 4.1:1 final drive or 4.3:1 and it will get up and go quick smart..(speaking from own personal experience here BTW)
    i dont even get the guys that put RB's in the S13...
    to much weight up front.. throws out the balance and handeling..may aswell be a drag car
    good luck
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    ur mad where u been hiding?? havent u seen leighs blue ke70 with the rb20 in it its stupid the ammount of firewall he cut out and had to chop the sump and mae it smalller, have u been in a 4ag turbo or a sr turbo ke they are already stupidly fast!!!!
    AE86 THE BEST
    Senior Member GOODY's Avatar
    Logan
    Any pics/details of it around anywhere?
  1. RB25 gearbox.
    By matt99 in forum Cars or Parts Wanted
    Last Post: 22nd March 2012, 10:12 PM
  2. SR20 to RB25 Gearbox plate
    By 85Trueno in forum Car Parts For Sale
    Last Post: 10th March 2011, 12:48 PM
  3. SR20 To RB25 Gearbox plates
    Last Post: 19th January 2011, 04:20 PM
  4. Rb25 A31 Cefiro SA
    By 1300wagz in forum Cars for Sale (Not Toyotas)
    Last Post: 18th November 2009, 10:06 AM
  5. 86 with rb25, in qld
    By scott_22 in forum General Topics (No Technical Questions)
    Last Post: 4th June 2009, 01:25 PM
