Hi guys recently bought an ae86 with a na 4age. The tune in it is horrible with the oil turning black in 500klm the motor seems to want to go but it's dead down low. Once it hits operating temps it idles at 1500rpm and what not.
Motor spec list is
koyo radiator
16v bigport full rebuild(smallport block)
toda piston
toda spring valve
toda high lift camshaft
toda cam gear
toda under bucket shim
toda conrods
metal head gasket
blacktop itb
billet sp tech trumpets
sard fuel reg
jubiride extractor
jazma exhaust (new high flow cat and muffler)
wolf ecu
So the motor isn't a stocker the last tune made 101hp at the wheels but I don't have a Dyno sheet I'm only going off the last owner.
My question is who is good with 4age and can tune wolf ecu??? And what type of power should I expect out of this setup?????
I'm not sure on the cam spec yet till I pull it off but it dose have an aggressive idle and seems to me the cams kick in at 4000rpm.
I'm located nsw so tuners in this state would be good cheers guys
