Results 1 to 6 of 6
Thread: Cost to replace welded diff?
    May 2011
    steve
    Default Cost to replace welded diff?
    I'm just wondering what the cost would be to replace a welded diff for passing a pit inspection? Am I able to get a mechanic to put in new diff gears fairly cheaply? Thanks in advance for the help.
    Eddie
    What diff? The gears will be fine to reuse... you need another centre. It'll take anywhere between 1-3h or so in labour plus parts. May or may not need new carrier bearings.
    Depending what diff you have makes it either a quick job or pain in the arse. Ae86 diff centers can be in and out in about an hour.
    You just drain the oil out of the diff, undo the axle bolts pull them out about 10cm, undo the center bolts and lift it out.
    Borg warner aka ke70 , ae71 diffs are a bit more effort
    May 2011
    steve
    It's is an S series off a JDM AE86. In all honesty, what would be the chances of passing a pit inspection with the diff welded? My mechanic seems to think it will be fine (he will be taking it over).
    Depends on who is doing the inspection, but you could just say it is a limited slip diff and chance it.
    Feb 2013
    Queensland
    Redcliffe
    Are you sure it's s series? It's either not an s series or it's not a JDM car since they came with t series.
  1. Just snapped a tseries axle, what diff should i replace it with?
    By ae86levin in forum Technical - Questions
    Last Post: 16th December 2013, 04:38 PM
  2. Need a diff welded!
    By x744 in forum Sydney & NSW Events and Discussion
    Last Post: 18th February 2012, 08:57 PM
  3. Welded Diff
    By dreny in forum Technical - Questions
    Last Post: 31st July 2008, 02:25 PM
  4. welded diff for sale
    By 13rendan_88 in forum Car Parts For Sale
    Last Post: 11th February 2008, 10:29 PM
