Fuck if only my engine wasn't costing me so much for repairs. I want your diff, I will purchase if it is still for sale in 2-3 weeks when I have money.
EDIT: Comes with t series - t50 tailshaft?
4AGE Bigport 86 RWD motor, very healthy internally recently compression tested at 210psi across all 4, comes with alternator, distributor,starter,inlet basically everything needed to run minus the water inlet also comes with Exedy triple puck clutch fitted, Loom, JDM ECU (a few more kws over ADM ECU tuning) will throw in K&n filter and oil catch can etc as well All this $1400
Here is a video of the motor running
TRD blue 5kg rear springs. top of guard sits level with top of tyre with a 185/65/14 tyre on a KE or AE $90
T series standard Diff centre good cond $50
T series 3.9 ratio C&P $100
Near new ultima KE/AE rear shocks shorter stroke than stock $80
KE70 standard castor rods $20
located gold coast Contact Alex via pm or txt 0405646133. Pics can be sent via Iphone to Iphone also. thanks
<<<<<<<Video of motor running if you missed the link>>>>>>>>>>
no worrys and sorry Didnt put Tailshaft up its AE86 front half and T series rear so yeah T series to T50. 250 for tailshaft
Are they balanced together? I assume you ran it no worries. If I can find the funds i'd swap you a t series box - borgy diff tailshaft from a manual ae71.
sorry mate tail shaft and diff have been sold.
noooo worries![]()
