adjustable arms wont help with toe, only pinion angle. the diff shouldnt have any toe unless it was modified or bent?
Hi guys, in need of some help!
I just had my r31 diff made up, where a mate welded on ke70 mounts onto the r31 diff..
I noticed when I put the wheels on there not aligned, (it hasnt got a panhard rod or swaybar installed at the moment). . Is there a way I could rectify this?
There both toeing inwards.. so could adjustable trailing arms do the job? Or....
(Drivers)
(Passenger)
Thanks gents!
Mmmm..The only mods I have done to it is mini spooled it and a twin caliper set up..
warped due to welding heat?
So pretty much its for the tip? Or is there ways I can go about to fix it?
Ya take it to your local drag car diff guy and get him to straighten the housing. It's pretty normal for a housing to warp, especially if it everything was set and welded in one quick go without letting it cool/paying attention to amount of heat dumped into the housing.
This method looks sweet:
This looks a little too backyard-ey for me:
When I welded mine it ended up bent. It was really surprising to see how much it moved when set up on V-blocks and rotated.
Any diff shop should be able to straighten it for you, or put you in touch with someone who can.
