Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 10 of 61
Thread: panda ae86 coupe N/A thrasher
    Jul 2009
    Kane
    Coburg
    Default panda ae86 coupe N/A thrasher. PICS up!
    Hey guys,
    i have to sell my car.. im in debt and id like to live a normal life for once lol.
    built for track driving in mind.
    Body suspension
    panda levin zenki coupe 83 model i think
    fairly straight body, rear corner ding and chip out of the wing.
    ideally i wanted to respray it
    jap doors (no intrusion bars) lighter
    engine bay has been done, all un usable holes filled
    battery to boot
    respray in pajero metallic blue
    rear TRD adjustable shocks
    6kg springs
    coilovers front
    unknown shocks (stiff)
    8kg springs
    cusco camber tops
    adjustable tie rods
    re built steering rack
    AJPS lock spacer
    PS arms
    Whiteline 22mm sway bar
    new bushes in most places
    2 x 14x8j SSR mkII -10 offset rims
    2x 14x8j SSR mesh -12 offset rims rear
    zenki front bar with lip
    vertex skirts
    vertex rear bar
    TRD fibreglass wing
    braided brake lines
    Engine driveline
    built 4age engine (first time 10,000 kms ago (pistons and freshen up), then head work done less than 1500kms ago)
    ballanced bottom end
    bigport head acid cleaned with slight porting
    20v silver quad throttles and 75mm trumpets
    heavier valve springs
    TRD 0.8mm head gasket
    HKS timing belt
    HKS adjustable cam gears
    TODA 288 8.5mm lift cams in/ex
    ADAPTRONIC ECU
    Denzo individual coils
    ZE injectors
    Fuel pressure regulator
    Heavy clutch
    20v flywheel
    TRD copy extractors
    2.5 inch exhaust
    TRD 2way L.S.D 4.1 disc rear end
    large Oil cooler
    inside
    Velo fixed back fibre glass seat old model
    Sparco steering wheel
    Greddy guages
    water temp, oil temp, oil press
    jap passenger seat
    there is prob more but i cant think of it at this stage..
    i also have a shed full of odd bits and pieces.. you can take the lot with the car.. got jap number plate, might even have a jblood rear bar.. fibre glass front bar brackets etc.
    whats it worth? id like to get around the $10,000 - $11,000 mark, but im willing to negotiate. id like to let it go within the next couple of months.
    car will come with 3 months rego
    all the thing needs is a good tune, then its ready for thrashing.
    im actually hoping to get it tuned asap so i can drive it myself. but as i said im broke lol.
    pics i have so far.. ill organise more this weekend.
    car located in adelaide SA
    If i dont reply, either i dont have what your after or you didnt offer enough
    kane
    Jul 2009
    Kane
    Coburg
    Jul 2009
    Kane
    Coburg
    PICS!
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    does this come with a complete front end?
    and is it a trueno or levin?
    Jul 2009
    Kane
    Coburg
    its a complete running car.. levin
    as i said.. these are the only pics i have so far.. new ones asap
    Jul 2009
    Kane
    Coburg
    ill take $9500 if someone buys it this month
    Senior Member crackett's Avatar
    Oh I have been waiting for a build thread on this for ages. Looks so tough man. $9500 is fucking dirt cheap!
    Jul 2009
    Kane
    Coburg
    bump.
    Reece
    Dernancourt
    little confused.
    so is it currently panda exterior, with freshly sprayed pajero blue engine bay?
    if you planned on a respray, what is the condition of the exterior paint currently?
    also, is it roadworthy, eg. can i buy it and register it?
    Jul 2009
    Kane
    Coburg
    yeh thats correct. panda outside, blue engine bay. was going to paint the outside in the blue. outside needs a lil attention (faded white) only 'damage' is mostly the rear corner.. but it would be a fairly easy fix. the rest of the body is pretty much straight as.
    yep ill be applying 3 months to who ever buys it.
  1. Time for me to move on.... AE86 Panda coupe track car
    By Touge Boy in forum Cars for Sale (Toyota Only)
    Last Post: 28th December 2009, 09:03 PM
  2. VIC: Panda AE86 Coupe Rolling Shell
    By luke86 in forum Cars for Sale (Toyota Only)
    Last Post: 24th June 2009, 08:34 PM
