I have a cheap set of Supertech on the shelf. If you are interested then send me a a PM.
For the cams it can be hard to impossible to know in advance if some cam grinds are truely dialed up right to work well with the VVT pulley. Seeing that you can't adjust a VVT pulley this is quite an issue. There is only one on the market that I know for sure is and that's the Tomei Poncams:
This ones a little sedate in the profile but it's proven to work ideal with a normal VVT pulley and not loose power anywhere.
Getting head work done might not be the right choice. Easy to go backwards on a 20V, if someone ports it and is used to V8's they could potentially stuff things right up.
Which ECU are you going to run?
