Results 1 to 10 of 24
Thread: 16v 4age with itbs misfiring problem, need help
Threaded View
    Member johnny2's Avatar
    Jan 2013
    Josiah
    Tasmania
    northwest coast
    Default 16v 4age with itbs misfiring problem, need help
    CAR - ke70
    MOTOR - ke70 running silvertop itbs and a microtech Lt-10s
    USE - daily
    PROBLEM/QUESTION - engine is misfiring and running rich
    OCCURS/STARTED WHEN - bought a ke70 with 4age about a month back and it turned out the wiring was a mess, so me and a friend who has been and auto electrician for the last 15 years, rewired a new custom loom, rewired the CD player, the hid lights and alarm, and when we had finished it all off and started it up it had a misfire, and was running very rich. we bought new spark plugs and spark leads, but the misfire was still there, my friend had these special adapters which you put between your spark plugs and ignition leads which have a light in them so you can see if it has a any of the cylinders aren't getting spark and they all were getting spark, he also tested the injector to make sure all of them had power and they did, so I'm really confused and need some help or pointers to what could cause the miss, any help or advice would be appreciated
  1. AE86 4age 16v wiring problem????
    By Dskew3 in forum Technical - Questions
    Last Post: 27th February 2013, 02:49 PM
  2. need some advice on installing 20v itbs on 16v 4age bigport
    By 2ftsim in forum Technical - Questions
    Last Post: 11th February 2013, 08:16 PM
  3. 4age misfiring and running rich
    By Sprinter Freak in forum Technical - Questions
    Last Post: 2nd May 2012, 09:04 PM
  4. 4age misfiring help needed.
    By Cerby86 in forum Technical - Questions
    Last Post: 7th November 2010, 09:53 PM
  5. st itbs to 16v bigport whats needed
    By sideburns in forum Technical - Questions
    Last Post: 7th August 2010, 05:39 PM
