This is how my vacuum map setup is like![]()
no dramas, im pretty sure you can buy the from T3 for around $50USD, i made mine out of a bit of ally and some festo fittings, worked a treat
Vacuum going to the catch can and then your rocker cover will be causing a vacuum leak. The diagram shown by Bento should be fine but with the FPR line aswell
Just fixed all that, and found a crack in an line as well, I replaced the broken line, with still no result. It's still misfiring
Is there anything else electrical what could cause it the misfire, what I can check
Thanks
See if the lack of spark is isolated to a particular cyclinder, a good spark is blue a weak one is red. Take the injector plugs off 1 at a time and if the running makes no difference you've isolated your lazy cyclinder.
Check the dizzy cap / rotor is in good condition. How did your auto electrician do the earths?
Is your alternator charging? 12v will put in waaay less fuel than 14v.
He earthed everything inside the cabin under the dash, but it was previously earthed on the fuel rail before the new loom, is that a problem?
so does my alternator need to be charging at 14v's or 12v's.
thanks for the help
Your alternator should be charging 13.5 - 14v. Was your issue there before you made your own loom? And was there anything else you changed at the same time?
Will this work
