Results 1 to 6 of 6
Thread: Mishimoto Fan shrouds
    Junior Member ship.wreck87's Avatar
    May 2014
    chris
    Nevada
    Fallon
    United States
    Default Mishimoto Fan shrouds
    Hello, I recently purchased the mishimoto dual fan shroud. I noticed that both fan have its own ground and power cable. The OEM has only one set of cable attached to the car. I might have overlooked at the forums for a correct way to install this on. Is there any diagram where it has the correct way? I think the relay will overload if I hook both the fan up. I also cut the OEM fan wiring harness off to install the new one. Do I need to get a second wiring harness, fuse, relay, and switch for the other fan?
    This is the website I found for wiring the fans. http://www.redlinedaily.com/automotive.php?article=AE86_electric_fan_install. But it is for both manual and thermo. I need both as manual. Is this good reference for making it both manual switches?
    Please help. I have a 1987 Corolla Gts coupe.
    Aug 2010
    Geoff
    mt dandenong
    Moved
    Senior Member Dylan's Avatar
    Dylan
    You can run the 2 fans together with no problem as long as the wiring is thick enough and just have one relay, one switch.
    This diagram could help.
    May 2014
    chris
    Nevada
    Fallon
    United States
    You have any recommendation on how thick the wire should be? Thank you!
    Dylan
    For both fans wiring for 20amps should be fine
    May 2014
    chris
    Nevada
    Fallon
    United States
    Thank you!
  1. Wiring a Mishimoto Dual Fan Shroud into my ae86
    By Mirko in forum Technical - Questions
    Last Post: 21st January 2014, 10:31 PM
  2. Clutch fan VS non Clutch fan 4age water pumps
    By hachirusto in forum Technical - Questions
    Last Post: 17th April 2012, 04:01 PM
  3. New clutch fan
    By haydenz in forum Cars or Parts Wanted
    Last Post: 28th March 2011, 10:12 PM
  4. clutch fan
    By deadlyuna in forum Cars or Parts Wanted
    Last Post: 31st May 2010, 12:39 PM
  5. 4age 16v fan fan clutch
    By hutto_t in forum Cars or Parts Wanted
    Last Post: 31st March 2010, 03:28 PM
Tags for this Thread
