Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Coilover insert nut is stuck
  1. #11
    Veteran AJPS's Avatar
    Lonsdale
    are you changing camber tops?
    I can supply shank nuts for the cusco tops
    yes
  2. #12
    Dec 2013
    luca
    tasmania
    launceston
    Staying with TTT camber tops.
    That's good too know incase I ruin this one, thanks
  3. #13
    Lonsdale
    i cant supply nuts for t3 tops they use a different style (but commonly available)
  4. #14
    Jun 2011
    james
    oxford
    general area
    England
    You risk damaging the insert by trying to grip it more.
    If it were mine I would be looking at using a dremel type tool with a high speed metal cutting disc fitted. Diagonally (because it looks like better access) cut across a flat of the nut until almost through and then use a decent cold chisel to break the nut off.
  5. #15
    Joel
    sticks
    Clean the shaft where you are going to grip it with brake cleaner. Find a small piece of fuel/heater/pvc hose about the same diameter as the shaft and cut it lengthways along one side and slip it over the shaft. Get some good quality curved jaw vice grips and put them on as tight as possible. Use your masturbating hand for extra strength. Use a good quality pneumatic rattle gun with the pressure turned up as high as you dare.
  6. #16
    Veteran drift kid's Avatar
    Glossodia
    Best in this thread
  1. vic: one ae86 front strut insert
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 20th November 2013, 01:38 PM
  2. NEEDED BADLY: 1 HTS102F insert
    By slide86 in forum Cars or Parts Wanted
    Last Post: 4th January 2010, 10:22 PM
  3. Diameter of front shock insert
    By drift kid in forum Technical - Questions
    Last Post: 21st December 2009, 04:17 PM
  4. ONE tokico HTS front shock insert
    Last Post: 15th September 2009, 04:08 PM
  5. Help now asap emergency (insert other in your face words)
    By scott_22 in forum Technical - Questions
    Last Post: 20th February 2009, 02:30 AM
Tags for this Thread
