Results 1 to 10 of 10
Thread: minimal camber adjustment
    Sep 2013
    Steve
    western suburbs
    Default minimal camber adjustment
    Hi All,
    Ive just rebuilt the front end of my car and have had the wheel alignment done.
    the most camber they could get on the drivers side was 0.5 degrees, whereas on the passenger side they could get 2.5 degrees.
    The car has:
    XT130 lower arms
    standard caster rods
    40mm RCA's
    standard struts
    lowered king springs
    adjustable camber and caster strut tops.
    Why is the drivers and passengers sides so different?
    Is this something from the factory?
    thanks, Steve
    Veteran AJPS's Avatar
    Lonsdale
    old car, could have some damage to the strut or chassis
    how do the wheels sit in relation to the guards etc? (is the track even)
    can extend one lca or modify top for more camber.....
    Sep 2013
    Steve
    western suburbs
    chassis looks straight, but I haven't taken any measurements.
    Ill put a straight edge on the strut tomorrow.
    Do you recon the stub axle could be bent in relation to the strut?
    thanks, Steve.
    Lonsdale
    yes i have heard of it and see it quite a few times
    we sell a weld on wedge brace to help that
    the strut itself rarely bends but the stub can where it joins the strut
    Jun 2011
    james
    oxford
    general area
    England
    Check that the engine crossmember is centered in the chassis.
    Sep 2013
    Steve
    western suburbs
    Thanks for the advice guys.
    Ill take some measurements to ensure the engine crossmember is central - cheers.
    assuming the issue is the crossmember, the maximum camber I can get on both sides will be 1.5 degrees. my plan was to get 2.5 degrees.
    So I'm thinking about buying new camber plates to get some more camber.
    How much camber can you get with a stock suspension setup and adjustable camber tops before the stock strut/spring starts rubbing on the strut tower?
    thanks, Steve
    Jun 2011
    james
    oxford
    general area
    England
    From memory you will get a little more than stock and enough to get yours equal both sides at about 1.5 degrees.
    You might be better off keeping your top mounts and getting adjustable lower control arms.
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Your issue is your king springs, they will be hitting the and stopping camber adjustment. If you've winded them all the way in.
    Sep 2013
    Steve
    western suburbs
    All - just as a follow up, Tottacrolla was spot on the money. The engine crossmember is slightly off-centred to the chassis - too far to the passenger side.
    there is a 5 or 6mm gap on the drivers side, whereas on the passeneger side there is no gap- so its roughly 3mm out.
    which according to my maths is approx. 0.5 degrees change.
    The next step is to get some adjustable lower arms or coilovers/camber tops to increase the camber.
    Veteran Konakid's Avatar
    Henry
    Eastern
    Good to hear, ive always wondered why they are slightly off with camber either side from factory nearly always. must be an issue from factoy.
  1. IRS Toyota Rear Camber Adjustment Discussion
    By bigm in forum Technical - Questions
    Last Post: 26th November 2013, 05:07 PM
  2. Replies: 62
    Last Post: 16th November 2010, 11:18 AM
  3. Wtb: hatch minimal - no rust and shifter..
    By DR86FT in forum Cars or Parts Wanted
    Last Post: 23rd September 2010, 03:23 PM
  4. Wtb: hatch minimal - no rust and shifter..
    Last Post: 22nd September 2010, 03:05 PM
  5. wtb 12 minimal records
    By slippry in forum Cars or Parts Wanted
    Last Post: 30th March 2008, 03:18 PM
