Results 1 to 6 of 6
Thread: Fueling sucks, not pump/filter. (4age with 30/32 weber downdraft)
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Default Fueling sucks, not pump/filter. (4age with 30/32 weber downdraft)
    Hey guys, I have really bad fuel delivery, it runs lean at high throttle, backfires, surges, etc. Was all tuned and running perfect, had a cracked piston/rebuild, then started having the fuel issues. I have replaced the fuel pump and filter, and inspected the soft lines/fittings, but I'm stumped now.
    I'm thinking:
    - Fuel pickup
    or
    - Clogged hardline
    or
    - Something up with the carby
    Anyone got ideas?
    Sep 2013
    Steve
    western suburbs
    have you tried removing the fuel line from the carbs and doing a flow test on the fuel pump?
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Measure the amount of volume/time? I think I'll do that yeah
    Sep 2013
    Steve
    western suburbs
    yeah, just get a 2L coke bottle and fill it up and time how long it takes..
    best to disconnect the fuel line after the regulator to ensure the fuel pump is working at 40PSI or whatever the normal working pressure is.
    You should disconnect the starter motor so don't drain your battery as you will need to switch the ignition to 'start' to get the fuel pump to run.
    Sep 2011
    Joey
    Queensland
    North Brisbane
    So I did a flow test, it's a carby setup with a facet pump no reg. It took 52 seconds to pump 1l, which seems like a long time considering the pump is rated at 180lph
    Sep 2011
    Joey
    Queensland
    North Brisbane
    It has been suggested that it could be timing as well, I check the valve and it's sweet, will check ignition when I get my timing light back.
    EDIT: All fixed. Fueling was an issue, but the timing was way out >_> i kinda assumed the mechanic I went to was capable of using a timing light.
  1. Joey's now 4age ae71 with 30/32 weber - running and on the road(ish)
    By undercoverninja in forum KE70 / AE71 Owners Forums
    Last Post: 14th February 2014, 01:35 PM
  2. WTB: 32/36 Weber downdraft carby
    By erik in forum Cars or Parts Wanted
    Last Post: 17th April 2013, 05:42 PM
  3. 4Age Big Port 32 36 Downdraft Weber Manifold
    By lil_cons in forum Technical - Questions
    Last Post: 1st February 2013, 10:31 AM
  4. Weber/Holley 32/36 with adaptor and filter
    By DAN-86 in forum Car Parts For Sale
    Last Post: 31st December 2008, 09:49 PM
  5. Replies: 5
    Last Post: 21st September 2007, 11:39 PM
