Results 1 to 6 of 6
Thread: Diff ticking when turning going slowly in reverse
    Sep 2013
    Steve
    western suburbs
    Default Diff ticking when turning going slowly in reverse
    Hi All,
    Ive noticed that my diff in my AE86 clicks when reversing slowly while turning in a circle.
    I presume this is some sort of locker in the diff that is letting the outside wheel spin faster, so the diff freewheels.
    Do you know what type / brand of diff that would be in my 86 making this noise? my guess is a Detroit locker (although im not sure you can get detroits for an AE86?)
    It’s a disc brake diff, I assume a T series. photo below.
    Thanks, Steve
    Sep 2013
    Steve
    western suburbs
    bump - anyone?
    the click/tick is timed with axle movement and its sounds like its supposed to happen. just not sure what type of diff it would be.
    thanks.
    Eddie
    Dude... you're asking us to tell you what brand if centre you have based on a sound that only you have heard? Almost ALL lsds will make some chattering/ticking when turning tight circles. Why don't you just open the drain plug and have a look?
    Sep 2013
    Steve
    western suburbs
    Hey Big T, I figured cause the ticking is so mechanical and perfectly timed with axle rotation it’s not an LSD but a locker of some kind.
    I figured there weren’t too many diff lockers (not LSD) available for a corolla so may be able to narrow down what type it could be.
    Ill check through the drain plug for some sort of marking on the diff centre.
    thanks
    Eddie
    Most clutch pack lsds will tick or chatter in tight circles. If there is a smooth billet finish, could be KAZZ, cusco, OS ginken. Rough cast finish could be factory LSD or trd. It'll be obvious if it's a spool/locker as they are shaped differently from the LSD centers.
    Aug 2010
    Adrian
    South
    Pretty sure I had the same noise in reverse with the same diff, check that your brake pads have all the little retainer clips
  1. brake pedal slowly away when braking
    Last Post: 22nd November 2010, 10:23 PM
  2. Slowly now.. EASY does it...
    By --Redwork-- in forum AE86 Owners Forums
    Last Post: 7th September 2010, 07:47 PM
  3. 4age - ticking noise
    By pogi in forum Technical - Questions
    Last Post: 13th July 2009, 03:17 PM
  4. Odometer Still Ticking
    By OMG-16V in forum Technical - Questions
    Last Post: 31st May 2005, 11:08 PM
