is a rubber suspension parts specialist based in Australia, with over 10 years’ experience in the automotive trade.
We choose to ONLY sell you rubber because that's what millions of kms of OEM research has worked out is best for your car. Essentially we believe that you should put in the same material as what you take out.
Being specialised in only one type of product, we can focus on delivering great expertise, excellent product quality, reliable and fast delivery and above all the most competitive prices.
Our range includes suspension, driveshaft components, strut mounts, engine mounts and more. We are a professional outfit with over 10 years’ experience in the automotive trade. Check out our specials below or visit our website for the full range:
Toyota Landcruiser Series 80 1991-92 & 1996-97 Rear Sway Bar Link Assembly:
This Rear Sway Bar Link Assembly is for 2 standard length sway bar links. These are required for standard height less than 2" 50mm of suspension lift on the vehicle. These links are designed and supplied with rubber bushes, made from high quality mild steel.
To Suit:
Landcruiser 1991-92 & 1996-97
Models : FJ80 HDJ81 HZJ81
$45 AUD
Toyota Landcruiser 100 Series 98-04 Sway Bar Bush kit (Rubber OEM replacement):
This sway bar rubber bush kit includes:
To Suit:
Landcruiser 100 Series (with IFS) 1998-2004
$43 AUD
