Results 1 to 9 of 9
Thread: My blue AE82 street build. 4ac --> 4age
    Member Chrisrundell69's Avatar
    Feb 2010
    West Side
    Default My blue AE82 street build. 4ac --> 4age
    Thought id start up a build thread for this to try and keep myself motivated to get this thing finished
    First post will be whats happened in the last year and second about where its at today
    Bought this about a year ago with the intentions of putting my built 4age into.
    Specs when i first bought it :
    160,000kms
    1.6l
    4ac
    5 speed
    king low springs
    twin cam front shocks
    twin cam front and rear brakes
    twin cam master cyclinder
    twin cam steering wheel, tacho and grill
    13 inch stockies
    Drove it around for a few months with the 4ac in it while looking for a wrecked twin cam donor car.
    finally a twin cam seca very cheap with 120,000kms on the clock. It had been hit hard on the drivers side, surprisingly still drove straight even after the hit.
    the day i bought the wreck the 4ac motor suddenly just died on me, no noises or nothing and then would not start again. started pulling out the 4ac after about an hour of trying to figure out what was going on with it. when i finally took the rocker cover off the 4ac it turns out the last owner had dropped a bolt into the oil fill hole and it was bouncing around inside the head occasionally and then finally jammed itself inbetween the cam and head.
    Next was stripping both the seca and my blue one down to start swapping over all the twin cam parts into my car.
    I had to use the following to upgrade from the carby 4ac to efi 4age
    Parts needed:
    All front wiring looms, dash, lights, engine, all fuseboxs etc
    front thermo fans (twin cam has one on the front one on the inside of radiator, 4ac has both on inside)
    obviously engine, gearbox twin cam cv shafts (single cam are smaller)
    Efi fuel tank
    Efi fuel lines
    i then split the 4age and gearbox and removed everything and gave it a bit of a clean up
    and then bolted the gearbox, all the fwd accessories and water pipes up to my built 4age and got it ready to drop in
    wiring was fairly simple as i basically just swapped all the wiring over from the twin cam except the rear lights loom
    kicked over first go and adjusted the timing to as close as i could get it for now, then fixed a few small coolant leaks.
    Still need to get a new exhaust made up and put all the interior back together. full specs in next post
    Feb 2010
    West Side
    This is how she was sitting about 4-6 months ago just after finished the conversion
    4age 16V Bigport
    TRD 264 cams
    cleaned up head
    extractors
    trd leads
    Polyurethane engine mounts
    Twin Cam wheels with 185/60 14 RE001's
    Twin Cam 23mm front swaybar with new super pro bushes
    Twin Cam 16mm rear swaybar
    Twin Cam strut brace
    Superpro front castor increasing bushes
    Kyb shocks
    King low springs
    Rear Strut Brace
    AE92 Series 2 front brakes with 258mmx22mm rotors
    Twin Cam rear brakes
    ae92 oil pressure and voltage gauges in custom box
    Have added a fair few things since these pictures so will update again soon.
    Veteran Konakid's Avatar
    Henry
    Eastern
    Cool hot hatch! I like them for some reason.
    Feb 2010
    West Side
    Cheers mate
    Bought a few parts for her since these pics
    Now has
    Full Whiteline swaybar kit
    Lightweight Flywheel and exedy Heavy duty clutch
    Super pro Castor increasing bushes
    Ae82 sprinter sedan grill
    New air intake setup and hydro dipped cam covers
    front and rear strut braces
    And also custom front bumper using ae92 sx bar and an old ae82 bar
    Heres how she stands as of today
    Looks good mate, not many of these left anymore , especially not in this condition.
    Site Supporter Javal's Avatar
    Josho
    Super tidy rig! That'd make an amazing little daily drive car. It's definitely asking for a subtle set of wheels though.
    Feb 2010
    West Side
    Thanks guys, yeah its a super fun little daily car. Wheels are definitely on the to do list, still trying to decide what wheels i wanna run. Some nice 14x7-7.5 mk2 or mk3 ssrs are looking like what i want at the moment but hard to find in 4x100. Also planning on getting an aftermarket ecu and ITBs in the future but we will see what happens
    Juston
    Sweet ride!
    Where did you get the adjustable rear bar and rear strut brace from? I didn't think they made them anymore.
    Feb 2010
    West Side
    Hey mate the rear strut brace I actually just had laying in the shed I can't remember what it was off possibly ke70/ae86 rear.
    And yeah whiteline don't make the rear anymore I found mine on ebay about a year ago just gotta keep looking eventually they pop up
  1. 4AGE 16v conversion - 4AC or AE82 4AGE fusebox?
    By 3SGEturbo in forum Technical - Questions
    Last Post: 27th February 2014, 10:05 AM
  2. brissy>>>4ac bare motor with everything just not attached
    By phil-720 in forum Car Parts For Sale
    Last Post: 30th March 2011, 01:20 PM
  3. clutchs/flywheel 4ac -> 4age
    By blake. in forum Technical - Questions
    Last Post: 28th July 2009, 10:22 PM
  4. 4AC -> 4AGE
    By xero in forum Technical - Questions
    Last Post: 21st July 2005, 05:24 PM
  5. 4AC -> 4AGE
    By Robo86 in forum General Topics (No Technical Questions)
    Last Post: 1st January 1970, 11:00 AM
