Results 1 to 10 of 11
Thread: 16v 4age stock ECU rev limiter problem
    Junior Member ElysiumGhost's Avatar
    Aug 2012
    Kalamunda
    Default 16v 4age stock ECU rev limiter problem
    1984 JDM MAP 4age out of an mr2 in my ADM sprinter
    stock ECU
    I've been driving my 86 around just fine for the last couple of weeks
    went to give it to it today and it would hit a limiter at 5500rpm in every gear
    i'm experiencing no other problems at all
    running fine, idling fine
    i went around checking all wires and earths were tight, all appeared normal
    fuel supply appears to be fine, new lines, filter, pump is less than a year old
    potentially a dead sensor? if so which ones would cause a limiter drop?
    has it entered some kind of limp home mode?
    i'll figure out how to get codes out of it as soon as i have time
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Do you have a check engine light wired in? A low limiter sounds strange to me, even with a constant check engine light on my last car it didn't change.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    I don't think its relevant to check engine fault cause that used to come up mid corners in my car and it never dropped the limiter
    Aug 2012
    Kalamunda
    hooked up a makeshift check engine light
    keeps throwing me 10
    which is starter signal
    so just take apart and make sure all the contacts and wires around the starter and such are okay?
    it starts without a problem though
    Start signal would only affect when it is cold and not reving cleanly etc... I'd be checking compression + timing next.
    Aug 2012
    Kalamunda
    timing is fine
    after a few misses and being able to push past the limiter once or twice by doing it gently, i was thinking maybe fuel supply, so i changed the pump and checked the lines
    no dice
    looking at maybe a faulty map sensor or a vacuum leak now
    Phirom
    I would also like to know what causes this.
    My car is doing the same, except I've got an Adaptronic on mine :|
    Veteran Skylar's Avatar
    Ken
    Cam timing? Fuel supply at rpm? Buy a pocket scope and watch the injector signal, then the coil signal. Figure out what's not working.
    Phirom, I have a pocket scope if you want to use it.
    Phirom
    Cheers Ken! I was going to check all my vacuum lines this weekend and maybe see if I can record a log from the ECU to see what's going on.
    Aug 2012
    Kalamunda
    all fixed
    turns out it was any of these problems that i found:
    leaking head gasket
    worn out valves
    cracked head
    don't put dodgy engines in your cars kiddies
  1. Replies: 0
    Last Post: 6th August 2013, 09:01 PM
  2. bee R rev limiter into 4age 16v
    By pen15 in forum Technical - Questions
    Last Post: 9th September 2010, 07:44 PM
  3. 7age flywheel bolt problem and rev limiter for carbs ???
    By SHADOW KNIGHT in forum Technical - Questions
    Last Post: 29th August 2010, 06:18 PM
  4. 4AGE/7AGE early rev-limiter and no power
    By Robo86 in forum Technical - Questions
    Last Post: 15th February 2010, 08:06 PM
  5. Bee*R Rev Limiter on a non ECU car? can it be done?
    By choonga in forum Technical - Questions
    Last Post: 26th May 2008, 09:14 AM
