Have a read of this and the links in the post, and if u have any more q's please ask..
I have an early Microtech MTX-8 "sequential fire version 2" running a ST20V
This has internal ignition drivers (pre X4 external ignitors)
I have a set of 1NZ COPS, and want to use, preferably configured as sequential fire.
I'm not sure if I'm asking this right, but;-
What is the signal the in built ignition drivers send out from this ECU?
What is the signal I need up to the IGT pin on the COP to get it to trigger?
Is there any way of making this ECU work with 1NZ COPS?
Any help would be much appreciated.
Cheers,
Ali
OK, read that.
I can't "simply splice into the IGT wire before the igniter" with out opening up the MTX-8 and spicing in internally
- not willing to do so either.
But this bit intrigues me
Can you link the club4ag thread referenced>?
Hear me out, have I grasped this correctly.
On COP - NOTE TO ANYONE READING THIS ****DO NOT EVER DO THIS*****!
IGT - Splice to 12v+
IGF - Meh
Ground - Ground to block - in my case use 4 individual grounds and join 4 separate ignitor wires from ecu set in firing order
12V - Splice to IGT
Splice IGT and 12V+ together> and trigger with the actual earth
Really?
Ali
Nah man, that's carazy.
Link me to the manual for that thing and I'll tell you how to configure it. But either way, you'll still trigger off the IGt wire. Just need to make sure the MTX8 can be set for going high (from memory) with a 5v wave. I really hope the signal coming out of the MTX8 isn't some specialised signal that's not a standard squarewave and made by microtech for their X4 box. In saying that, I've seen X4 boxes used on other ECU's so you're fine.
LOL - I though that sounded bit Wak.
However, didn't stop me from trolling club4ag for hours looking for the above reference thread.
This is an older Microtech, well before X4 box - It has internal ignitors.....The "X4 box" is internal, not separate.
I think "Direct fire" was the term coined?
Microtech has killed the MTX-8 manual off there site.
When you click it, it only shows the later MT/LT which has the X4 box.
- Manual -I can configure as per this - have all screens
- Wiring
The difference is the ignition output -
I have the Yellow, Yellow/Black trace, Orange & Orange/Black trace wires coming straight out of the main unit.
Its more like this Mazda 13B diagram, no ignitors, just straight to the coil.
Isn't an ignitor just a rapid earth?
But yeah, have a think about this and come back to me.
Cheers,
Ali
A dumb ignitor just increases the current that you can send through your coil. The electronics in some ECUs can't handle enough current to run the coil directly, so the ECU runs the ignitor and the ignitor runs the coil.
In general:
12V - gets 12V with ignition
Ground - gets ground (hey, hey, slow down egghead)
IGT - This controls the ignitor/coil, pulls low to start the dwell time, and goes high to cause a spark.
IGF - Feedback to the ECU to confirm the coil fired. Irrelevant for any aftermarket ECU.
To answer your specific questions: Your ECU will output a square wave on the ignition outputs. The coils expect a 5V square wave to drive them. If the ECU output voltage matches then connect it up and you'll be fine. Each ignition output gets wired to the IGT on a coil.
Your ECU has an ignitor in it (or 4 actually) and the coils have ignitors in them. So it's a bit of overkill, but shouldn't cause problems.
EDIT - Hadn't checked the expected voltage on IGT. It's 5V. ECU ignition out needs to match this.
Also just had a look at the linked diagrams. The yellow, yellow/black, orange and orange/black wires run the injectors, not the ignition.
EDIT - Need to check ECU output voltage.
Ugh, I thought Matt linked you to this:
which is completely clear. 5v squarewave, fires going high, 2-3msec dwell.
The documentation is so shit, I have no idea of what's going on. Totally regret offering to do this, haha.
As far as I can tell, set the ign output to -ve and it should work. You want to wire to the grey/*colour* wires. Didn't check but some are wired in firing order and others in cylinder order. From memory micro's are in firing order so 1 is 1. 2(ECU) is 3(engine), 3 is 4 and 4 is 2.
Does it say anything about ignition output voltage in the manual? I did a search using an iPod app but it returned nothing. Can't tell if the PDF is an image or a document.
Realised reading Skylar's linked thread that coil ignitor needs a 5V square wave. ECU igntion output may be a 12V square wave. This may cause issues.
