Results 1 to 10 of 14
Thread: COMPLIED i Trueno Hatch Possiably Show interest
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Default COMPLIED i Trueno Hatch Possiably Show interest
    Hi all
    This car will be wrecked out if i get enough people wanting main items.
    Please contact us via email if serious and first in best dressed for the parts .
    prices are as follows
    16V Engine package which includes complete engine which is a multi rib 16V small port head converted to RWD with a big port to small port adapter. Coil / Igniter, ECU, Engine loom , Map sensor etc
    $2000 ## SOLD ##
    JDM T50 Complete GBox with mount TRD short shifter , slave cyclinder etc $600
    JDM T series Tailshaft $200
    Complete JDM EFI Fuel tank with Pump sender etc $550
    Full Front end TRUENO conversion, Bonnet , guards, Headlights with HID setup, Full Front of the car LOOMS & under dash looms etc, Light switch, Speedo cluster surround, Grille, Either this Zenki Bar or a complete Kouki Front bar assy, Guard lights, Grille support. $2500
    Driver Fixed back seat ( Small arse size) and Rail $400
    Rear TRD Green short stroke adjustable shocks $ 175
    Rear TRD Springs ( U/K rate ) $75
    Front struts with Adjustable Inserts and camber tops ( U/K rate spring) $575
    Front Brake Brackets $65 pr
    Front Hubs $185 or $225 with rotors ( On HOLD )
    Front JDM 2022 calipers complete $285 ## sold ##
    Front GTV Grey Door trims complete $250
    Half cage Roll cage $450
    Complete set of very good redlines / Centre panel / Numberplate lamps and looms $ 650
    Good Rear Kouki Bar and Mounts $400
    2 x 15 x 7.5 -6 SSR MKII and Tyres $700
    2 x 15 x 7.5 -?? XR4 and Tyres $700
    Rear Hatch and TRD style Wing $475
    COMPLIED shell with complete rear side glass & trims , doors complete, Sunroof working, minimal rust it looks like. $2750
    Very good Koyo 2 core $250 ## SOLD ##
    Brake booster $155
    Clutch master Cyclinder $75
    4AG Accelerator cable $75
    Speedo cluster $ 225
    Dash plastics BLACK $ 275
    GTV Shorter centre console $55
    Front Black seat belts $165 pr
    Pedals Clutch / Brake JDM Accell $175
    Speedo Cable $55
    Mirrors Kouki $155
    Extractors $175
    ARC Intake Airbox Setup $225
    Front Strut Brace $100
    PWR str arms 185 or $225 on lower control arms
    Complete 3dr Locks ( Doors/ Hatch / Ignition) $250
    LHS GT Apex Seat complete $225
    Washer bottle $75
    Radiator overflow bottle $75 with mount
    UNCRACKED BLACK Dash $575
ID:	32803Click image for larger version.
ID:	32804Click image for larger version.
ID:	32805Click image for larger version.
ID:	32806Click image for larger version.
ID:	32807Click image for larger version.
ID:	32808Click image for larger version.
ID:	32809Click image for larger version.
ID:	32810Click image for larger version.
ID:	32811Click image for larger version.
ID:	32812Click image for larger version.
ID:	32813Click image for larger version.
ID:	32814Click image for larger version.
ID:	32815Click image for larger version.
ID:	32816Click image for larger version.
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    West
    Ill take centre console, the hatch striker off the hatch itself if you will seperate ot have another. Do you have the taillight interior trim and the hatch trim panel?
    Craig
    Upper Caboolture
    Hi
    What centre console you after as this has the GTV version, but also have the standard GT apex like the ADM ones in black
    Have hatch strikers and have the full 3 pieces in the hatch area in black , plus the hatch supports and the hatch tray but not cheap at all
    Senior Member jamiesbrain's Avatar
    May 2014
    Jamie
    I will take the dash.
    West
    The GTV would be fine, or whatever really as long as its not rooted and I liked the price of the one you listed here.
    I cant decide on the rest unless you give me prices on those bits... Ive got a wtb with a bunch of things in it. If you want you can quote me on my needs.
    Aug 2014
    Shane
    Nsw
    Any trueno bumper emblem ??
    Aug 2014
    Alex
    Gold Coast
    Hello Craig,
    I'm quite interested in a few parts, could you please pm me the details i.e. condition and noticeable flaws in the first 4 items listed?
    While I don't really need them if we can come to a deal I'll more than likely take them.
    Here's what I'm interested in:
    JDM T50 Complete GBox with mount TRD short shifter , slave cyclinder etc ( any issues known? )
    JDM T series Tailshaft ( already have a spare but feel like I should get another haha )
    Complete JDM EFI Fuel tank with Pump sender etc ( just to be sure but this is the one with a simple internal baffle and also does it leak anywhere?)
    Front GTV Grey Door trims complete ( any visible blemishes?)
    Also while not listed here I was wondering if you had some interior plastics? Particularly for the 3dr boot/hatch itself and also RHS on the edge of the roof lining in between the front and middle pillar.
    Finally I am looking for the small little grille piece that sits between the pop up lights, as shown in picture 2. Rather than ruining the complete trueno conversion you have listed I was wondering if you may have one of those around in decent condition?
    Thanks a bunch and I'll look forward to hearing from you soon.
    Alex
    Craig
    Upper Caboolture
    Hi All
    Look s like the following is SOLD
    Shell ( Complied) Redlines
    Fuel tank setup
    Engine Package
    All wiring
    Still available
    Trueno conversion, consisting of Guards Bonnet, HID Headlights setup. Also a Kouki Front Bar Assy Complete in Stock ( No Wiring Looms )
    TRD Green shocks
    Rear Hatch with TRD wing
    Tail shaft
    Rear Springs
    Front Zenki Trueno bumper bar assy
    T50 Gearbox setup (SOLD ) have others
    Speedo cable
    Extractors
    REAR 4.3 Disc to Dsic LSD complete ( SOLD )
    Half Roll cage
    Kouki Instrument cluster ( SOLD ) have others
    Full front suspension / subframe / rack
    Front calipers ( SOLD )
    Front Hubs n rotors
    JDM washer and windscreen bottles
    Airbox setup ( very rare)
    GT Apex LHS seat
    Fixed back drivers seat
    GTV Front Door trims
    Wheels XR4 & MK II 7.5 -6
    and more
    Jan 2014
    Adrian
    Quebec
    Montreal
    Canada
    pm sent
    Craig
    Upper Caboolture
    Hi all
    Ok this car is now back up for sale (Complied ) YES THATS RIGHT THE CAR HAS NOW BEEN COMPLIED
    As follows
    Can be brought as you see it minus the following for $7500 ## NOW $6750 ####
    No Disc rear end
    No engine assy package including radiator loom ECU Coil/Igniter Starter etc , Exhaust system
    no tail shaft ( $200 if rq)
    no gearbox assy ( $550 extra if req)
    Will supply an S series diff if needed FREE or a JDM drum Lsd or a JDM disc but with no centre for extra
    No Half cage ( $450 extra)
    No Front Calipers
    Car located Brisbane North Side Queensland
    CONTACT me if interested 0408998795
  1. Wrecking ADM Hatch
    By 44GTE in forum Car Parts For Sale
    Last Post: 26th April 2014, 04:26 PM
  2. Wrecking Out AE86 Trueno Hatch
    By 44GTE in forum Just JDM Imports
    Last Post: 26th April 2012, 05:24 PM
  3. SC12 with intercooler and some piping,or possiably SC14
    By jet81j in forum Cars or Parts Wanted
    Last Post: 8th June 2010, 11:49 PM
  4. wrecking AE92 SX Hatch 1990 model
    By riojin in forum Car Parts For Sale
    Last Post: 23rd September 2008, 04:52 PM
  5. wrecking ae82 twincam hatch
    Last Post: 27th August 2008, 05:30 PM
