Results 1 to 5 of 5
Thread: Brake Caliper Question
    Senior Member RolandGTV85's Avatar
    Roland
    Bassendean
    Default Brake Caliper Question
    Hi,
    Does anyone know the part number or what the small steel metal bracket is called that actually holds the brake pad in place? One of the clips on my front drivers side is damaged and i need a replacement.
    Any help appriciated or if someone has one to spare?
    Roland
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    You mean the part at the top of the brake calliper? with the curve in it?
    Roland
    Bassendean
    I mean this clip in this photo, its like a little spring clip that holds the pad in the caliper. I want to see if i can get one from toyota or buy one from someone who has a spare which is unlikely.
    Eddie
    Raid the wreckers. I'd bet that this will be common among single piston sliding calipers in other toyotas.
    Mar 2013
    Mirko
    Actually have standard ae86 front brakes at home I'll check if I have that for u
  1. Caliper question regarding ke70
    By stuch in forum Technical - Questions
    Last Post: 3rd May 2014, 08:36 PM
  2. WTB: JDM brake caliper
    By KE70lover in forum Cars or Parts Wanted
    Last Post: 13th July 2011, 11:45 PM
  3. FC Caliper Question
    By wideslider in forum Technical - Questions
    Last Post: 1st June 2009, 09:53 PM
  4. T-18 brake caliper
    By SON57A in forum Cars or Parts Wanted
    Last Post: 16th June 2008, 12:57 PM
  5. FC Brake Caliper Conversion
    By 70XIN in forum General Topics (No Technical Questions)
    Last Post: 25th February 2007, 10:21 AM
