Results 1 to 6 of 6
Thread: 1983 corona coilovers
    Aug 2014
    jason
    IE-MH
    navan
    Ireland
    Default 1983 corona coilovers
    is there an off the shelf coilover kit available for the t140 corona?
    if not what coilovers fit front and whats my options for the back?
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Any AE86 coilovers etc with TOYSHOP ENGINEERING (New Zealand) top plates
    Aug 2014
    jason
    IE-MH
    navan
    Ireland
    just getting back to this now...
    will everything else just bolt up with the top plates?
    or do i need to change anything else?
    Veteran Konakid's Avatar
    Henry
    Eastern
    I personally wouldnt use ae86 struts, for the following reasons:
    - you are down grading the size of the stub axle and therefore strength of the wheel bearings. (AE86 weighs 200kg less than corona)
    - Stock ae86 brake is 225mm, stock corona is 250mm or 258mm vented if you bolt on ma61/ra65 brakes + rotors.
    I have used stock RT142 struts with RA65 vented brake calipers and rotors (bolt stright on) with custom shortened strut by 50mm with a coilover kit welded on and a short stroke KYB shock. Cambertops i have used S13/14/15 Nissan silvia Cusco they fit with filing of about 3mm of 2 of the strut holes. Cusco make a top for the RT142/TT141 they can be found on Yahoo japan, google Jesse streeter he can buy them and send them to you for a small fee.
    RA65 power steering steering arms are shorter and give more lock and quicker steering also. Dont use an MA61 supra strut the kingpin angle at the stubaxle is different and it will give +2 degrees positive camber.
    Veteran AJPS's Avatar
    Lonsdale
    was about to post what Konakid said
    Aug 2014
    jason
    IE-MH
    navan
    Ireland
    S13 tien coilovers in the front 8kg springs
    S13 lower controls arms
    S13 knuckles and sr brakes
    Aw11 mr2 rack ends and s13 tie rod ends
    i got a pm to say this will work in the front of my corona,
    im waiting to hear back from ajps.
    anyone else able to help me out?
  1. Sunny Coast - 1983 Toyota Corona XT130 for sale $600! - good daily!
    By 73ta22 in forum Cars for Sale (Toyota Only)
    Last Post: 4th November 2011, 03:16 PM
  2. Qld 1983 Toyota corona mods
    By rona_83 in forum Cars for Sale (Toyota Only)
    Last Post: 21st April 2011, 09:12 AM
  3. FS: Toyota Corona 1983 Auto 2nd owner Sydney, NSW
    By ghetto ke in forum Cars for Sale (Toyota Only)
    Last Post: 3rd August 2010, 11:52 AM
  4. 1983 ae86 4agze caged lsd coilovers
    By SEXY 16 in forum Cars for Sale (Toyota Only)
    Last Post: 11th October 2009, 05:05 PM
