Results 1 to 2 of 2
Thread: Putting the call out for Mictrotech 4AGE stock ST20V timing and fuel maps - Want to compare screens
    Mar 2011
    Ali
    Default Putting the call out for Mictrotech 4AGE stock ST20V timing and fuel maps - Want to compare screens
    Car - KE70
    motor / part in question - Stock ST20V ECU / tune
    problem - Microtech
    occurs/started when (if applicable)- Bought running motor and ECU in FWD donor car.
    Changed to RWD with open quads, cleaned up some very ordinary wiring, now doesn't want to behave.
    personal situation (if applicable)- Need to get a 1/2 decent street tune / base tune in place so can drive it to dyno
    Anyone on here that has a stock ST20V running a Microtech and knows the hand controller that can give a run down of settings in timing screens 23 - 28 are most important to me.
    Would like to compare Fuel load maps 2-16 also as mine is very rich.
    Also some screen 31 settings
    Maybe a few others.
    Help a brother out, only really need it to behave up to ~4000 rpm.
    Cheers,
    Ali
    Oldschool Member
    May 2006
    Tan
    I've tried to find some maps searching through the net and have had no luck so would be great if there was somewhere that people could post them
  1. Replies: 4
    Last Post: 6th November 2011, 11:15 AM
  2. Stock 4AGE Fuel Pressure Regulator
    By timbo in forum Cars or Parts Wanted
    Last Post: 23rd August 2011, 12:29 PM
  3. Replies: 6
    Last Post: 13th December 2006, 07:28 PM
  4. Fuel Tank putting it in
    By Clinton in forum Technical - Questions
    Last Post: 8th July 2006, 07:05 PM
