Doesn't matter that much. It'll be fine as long as it's bigger than throttle body size. Stick to close to TB size so 2.25" for the reasons listed below. Is 55mm butterfly OD or TB OD?
FWIW, the bigger the pipe, the lower the velocity and lower the pressure drop across the pipe. But by having (sharp) transitions, you upset the flow (create swirls) which is a pressure drop.
