Results 1 to 6 of 6
Thread: T5 Gearbox
    Joel
    sticks
    Default T5 Gearbox
    Has anybody put a BW T5 into an AE86? I would like to know if it will fit with only minor tunnel massaging before I start buying parts.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    how would you adapt it? cut and shut on the bellhousing?
    Joel
    sticks
    It's for a non-Toyota engine that originally came with a T5. The T5 is about the same strength as a W5x so if it fits I'd use it, otherwise I'd adapt a supra box.
    Should be falrly similar in size to a w58 too from memory.
    West
    T5s should be rebuilt and shimmed for higher hp applications, the light alloy casing distorts under full power and you experience a lot of end float misaligning gears in the box. As such they shim the cases against the shafts somehow to keep it in tolerance. There are a lot of saloon car racers that have to use them and they are widely regarded as being a crap box amongst these people.
    Stick with w58!
    There are also allot of t5 to w58 bell housings out there
  1. JDM T50 22 spline gearbox and K50 Gearbox
    By wrathchild in forum Car Parts For Sale
    Last Post: 19th September 2013, 08:03 PM
  2. Replies: 12
    Last Post: 11th October 2012, 12:42 AM
  3. CA Gearbox, T50 Gearbox, Ecu's,Exhaust QLD
    By damien454 in forum Car Parts For Sale
    Last Post: 23rd July 2012, 01:02 AM
  4. WTB: AE86/AE71 T5 Clutch Fork
    By gen4lx in forum Cars or Parts Wanted
    Last Post: 5th August 2009, 12:10 PM
