bump $1800
Decided to move on from my 1982 Toyota Corolla KE70 SE.
I have owned this car for a number of months, it's completely original and well kept.
It has a healthy 4k engine backed with the standard auto, also healthy.
235,XXX k's and the counter still works, so does the clock!
No smoke, no overheating, no oil leaks.. doesn’t even require the choke to cold start!
The car has dents and scrapes here and there, the worst would be RH rear wheel arch and door.
I have a spare door with a very minor dent.
No visible rust, a few pinhead sized bubbles around the fuel flap.
Had a little rust in the corners beneath boot seal, a wire brushed has been used to clean up and coated with rust converter.
Interior is very good except the front seats are ripped.
Dash has two small cracks, nothing major.
Everything works including the original AM radio.
I will also have some needed manual conversion parts;
Pedal box, tail shaft, clutch cable, flywheel & manual console.
*missing gearbox, shifter, clutch/pressure plate, speedo cable*
Somewhat a regretful sale as it's beautiful to drive & never misses a beat.
I'm going to start with the asking price of $2,000. Inc. registration (15/10/14), no rwc but was passed when I purchased it.
Will come with original plates from 1970's also!
Located in Cranbourne, vic.
Contact me via text on 0411 296 564.
bump $1800
sold
