Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 11 to 20 of 51
Thread: im lost why is this thing not making power what are your thoughts
  1. #11
    Jul 2009
    shaun
    nsw
    port macquarie
    he has set the cams at 10 and 2
  2. #12
    Jul 2009
    shaun
    nsw
    port macquarie
    Cam timing is set up at 10 and 2 the plugs are a little to the lean side if anything the tips are white but only just and it is sometimes a pain to start when cold needs a little throttle to fire
  3. #13
    Jul 2009
    shaun
    nsw
    port macquarie
    Yeah ok that makes sence im running 98 pump fuel nothing else and mostly caltex. Ive replaced fuel filters ect too.
  4. #14
    Marco
    North Adelaide Suburbs
    FYI. Toda racing 264 camshaft timing recommendation as follows.
    Intake =105 degrees
    Exhaust 108-110 degrees.
    If you like I can photograph the cam cards for you tomorrow and email them. Pm me if you are interested.
    Also, if you are keen on a black top conversion with garage annex water kit, pm me. Cheers
  5. #15
    Jun 2011
    james
    oxford
    general area
    England
    Cam timing can make a lot of difference and the only way to set it up correctly is on the dyno
    Assuming it was tuned on a rolling road you could also look at peripheral stuff like binding brakes and tight differential bearings.
  6. #16
    West
    What sort of manifold adapts the blacktop throttles to the 16v head? Maybe it has a poor design?
  7. #17
    Mar 2013
    andrew
    perth
    whats "10" and "2"
    i only know setting up via lobe centers and LSA. as slimer said with "108" "105"
    110 being about standard.
  8. #18
    Apr 2011
    Steve
    10 & 2 are probably marks on the timing pully's so he has NFI where they are actually dialled in
    Toyota specify maximum lift at X degrees. There is a procedure to follow how to do it correctly.
    A lot of cam manufactures say at x ammount of lift ( usually 50 thou ) should be x degrees, don't use this method as you dont know the cam lobe profile.
    Sprinter Veteran
  9. #19
    Marco
    Also, I recommend taking off the front cam pulley cover and posting a photo. Also, pull off your rocker covers and using an extended mirror (get from repco etc) you should be able to read the cam lift and duration on the far end of the cam shafts closest to the fire wall. Post up this information.
  10. #20
    Daniel
    GC Hinterland
    1. Make sure cam timing is not out by a tooth.
    2.Dial in the cams properly.
    3. Make sure the timing is set correctly with the cams dialed in.
    4. Re tune.
    However 115hp at the wheels is a healthy figure for a stock 4age with mild cams. But your car sounds like it it feels 'flat' definatly sounds like a timing issue.
  1. Apexi Power FC + Commander | HKS Cams for 4AG and a Blitz thing
    By OnBail in forum Ebay Items - My Stuff
    Last Post: 14th September 2011, 07:28 PM
  2. Thoughts and help on this setup?
    By Hazzard in forum General Topics (No Technical Questions)
    Last Post: 28th August 2009, 10:22 PM
  3. are my thoughts completely off?
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 4th February 2008, 05:56 PM
  4. Imports and Thoughts
    By Kebin in forum General Topics (No Technical Questions)
    Last Post: 15th April 2006, 10:37 PM
