Roll3r number plates (green)
1984 toyota corolla ae71 spirit model highly modified road registered gocart
264,000kms on the car and gearbox, unknown Kms on engine (was told "low Kms")
4age red top with 7 rib block/oil squirters, tvis (engine registered with car)
t50 5 speed manual gearbox
Heavy duty rpm clutch
custom built extractors with 2 inch system with resonator and muffler and twin dump pipes
k and n pod filter
one piece tail shaft with tail shaft safety loop
t18 diff with 1.5 way toyota lsd and corona disc brakes
carina front struts with vented discs twin pot calipers custom made adjustable coil overs with king springs with custom made shocks
Qfm brake pads
r32 master cylinder
brake bias adjuster
Braided front brake hoses
sigma control arms
rebuilt steering rack
front strut brace
camber tops
Uthethane bushes throughout the whole suspension
Whiteline sway bars front and rear
whiteline adjustable panhard rod
traction brackets
adjustable top rear trailing arms
rear ford falcon ghia cut down springs with custom made shocks
custom front from a ke70 which has been widened and shaped to suit a hilux bonnet
custom flares cut and shut to suit car
jza70 side skirts cut and shut to suit car
ford arctic white respray
clear altezza headlights
custom tinted rear tail lights
Bmw side indicators
custom chrome number plate surround
t18 bumpers widened and cut and shut to suit
custom front splitter
new windscreeen
tinted windows
central locking and alarm
solex locks
push button ignition
custom black and bright green interior
custom cluster with clear perspex
3x center gauges oil temp, oil pressure, water temp
recaro front seats
Aftermarket sports steering wheel with boss kit adaptor
front 13x8 +3 super lights with 20mm bolt on spacers with 215/50/13 bridgestone eagers
rear 13x8 +3 super lights with 25mm bolt on spacers with 235/50/13 bridgestone eagers
Spare 13x8 +3 super light with 215/50/13 hancook tyre
comes with lots and lots and lots of spares
(Bonnet, tail lights, head lights, grills, seat rails, clear altezza front indicators for front bumper, suspension parts, interior parts, mdf/carpeted boot inserts, catalytic converter)
Paint has a few imperfections, small amount of rust in rear quarter panels
needs a custom front grill
interior 90% complete
Car sits 120mm off the ground except for the bend on the exhaust just before going over the diff, sits at 90mm (which I was going to get modified when I got the catalytic converter installed)
registered till october 22nd sold without roadworthy
$10,000 (or $9,500 without wheels/tyres) (or $9,000 without wheels/tyres and personalised number plates)
if you are seriously interested please come inspect and test drive the car
car located in emerald victoria
paul
Any questions don't hesitate to ask![]()
