Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Fuel pressure regulator to suit carb, return line, fuel pump questions.
  1. #11
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Nah, keep same lines, you're over thinking the fuel system, carbs don't need much fuel, literally just put a facet pump on and don't worry about anything else ever.
  2. #12
    Jun 2009
    Ollie
    Legend, thanks Jacob.
  3. #13
    Aug 2012
    Jarrad
    east
    Wow, my old thread getting bumped up.
    Life got in the way - still haven't got an engine in my car, lol.
    But yeah, super low pressure. Hard/soft lines are fine. Braided with $50 fittings is mad overkill
  4. #14
    Aug 2012
    Jarrad
    east
    Bumping this thread to keep everything in one place.
    On the ADM tank - these are the lines.
    Got to wire in my fuel pump and hook everything up.
ID:	36714Click image for larger version.
Name:	Photo 7-03-2016, 7 49 02 PM.jpg
ID:	36716Click image for larger version.
Name:	Photo 7-03-2016, 7 42 04 PM.jpg
    Making sure for my and other people looking, this is correct?
    Also, in the engine bay there is that hard line that loops from the bottom near the fuel rail to up near the brake booster. What is this for?
    My car never came with any lines or anything fitted correctly
ID:	36713   Click image for larger version.
  5. #15
    Senior Member Dylan's Avatar
    Dylan
    That line that loops back around is the where the fuel went after the fuel filter and then into the fuel pump, this is only used on the 4AC engine so not needed on a 4AG (remove the clamp and take the line out of the holder).
  6. #16
    Aug 2012
    Jarrad
    east
    Good to know, I was planning on removing it as it doesn't seem to do anything.
  7. #17
    Mt Macedon
    You've labelled the fuel lines correctly, but it is also possible to use the two 6mm lines as feed and return, leaving the smaller line for the vent. Probably negligible difference, but may solve some idle problems if you are pushing the limits of the stock stuff.
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. Replies: 6
    Last Post: 29th May 2010, 10:36 AM
  3. fuel pressure regulator in and out?
    By Mr Awsome in forum Technical - Questions
    Last Post: 16th December 2009, 07:26 AM
  4. t18 fuel line and return fuel line
    By fozz in forum Cars or Parts Wanted
    Last Post: 23rd December 2007, 04:55 PM
  5. WHAT FUEL PRESSURE REGULATOR
    By PRJECT in forum Technical - Questions
    Last Post: 3rd June 2006, 02:40 PM
