Results 1 to 4 of 4
Thread: RWD sandwhich plate...
    Aug 2013
    michael
    victoria
    east side
    AUS
    Default RWD sandwhich plate...
    Ok i have a fwd 4age going into an ae71, have the extractors manifold cooling etc sorted, now just down to the fiddly bits.
    -The motor is out of ae92, has 212mm clutch/flywheel,, i have the spigot bearing for the motor, i have searched but no solid answer, can i use the fwd clutch/flywheel? is there any difference? also which starter do i use?
    -Do i need a sandwhich plate? kind of in the dark about this one..
    -Also, any info on doing the throttle cable, or any other relevant info that usually gets skipped over in conversion guides is much appreciated as im trying to get it done as smoothly and hassle free as possible..(dream on haha)
    any help much appreciated guys, cheers,
    Member phoenix's Avatar
    Nick
    Fwd clutch and flywheel are exactly the same except the spigot bearing
    You can use a 4ac starter but best to use a 4age one due to the heat of the exhaust going over it
    Yes you need a sandwich plate, use the one on your 4ac engine since that is the correct rwd one
    There are lots of throttle cables you can use just go to a wrecker with your old one and find one slightly longer
    KE70 and AE82 both work but are a little on the long side, I believe the corona cables are a better fit
    Formerly 86 Nick
    Aug 2013
    michael
    victoria
    east side
    AUS
    cheers mate helpful reply, i assume fwd/rwd 4age starters are the same?
    Nick
    Yes the starters are the same
    Formerly 86 Nick
  1. 4AGZE Spacer Plate (for rwd intake)
    By Nikkojoe in forum Cars or Parts Wanted
    Last Post: 18th September 2009, 09:03 PM
  2. 4ac/t50 sandwhich plate
    By shakes in forum Cars or Parts Wanted
    Last Post: 2nd September 2009, 04:23 PM
  3. 4a rwd sandwhich plate
    By richo in forum Cars or Parts Wanted
    Last Post: 24th June 2008, 04:34 PM
  4. WTB: Oil Cooler/Filter Sandwhich plate
    By 4A-GE Power in forum Cars or Parts Wanted
    Last Post: 11th September 2007, 01:06 PM
  5. Oil cooler sandwhich plates
    By slydar in forum Technical - Questions
    Last Post: 8th August 2006, 09:58 PM
