Yeah it'll cause low oil pressure as the oil is trying to squeeze past the filter in the reverse direction. It's made worse if you have an anti drain back valve on the filter. How long did you run it for? Shouldn't be any lasting damage as long as it wasn't for extended periods/high revs.
Sent from my iPhone using Tapatalk
