Results 111 to 120 of 155
Thread: Huws 4agte ae86
Threaded View
    Veteran slide86's Avatar
    Huw
    Hills
    Default Huws 4agte ae86
    The car
    engine:
    4agze 7 rib bigport from ae92
    complete rebuild by me
    ARP headstuds
    ARP main studs
    ARP rod bolts
    ARP flywheel bolts
    balanced bottom end
    honed and new acl rings
    decked block and head
    tunnel bored with 10thou oversized acl bearings
    OEM head gasket
    Acid dipped head
    three angle valve cut
    new valve guides
    OEM gasket and seal kit
    RC Racing 440cc injectors
    Modified fuel rail to suit speedflow fittings
    Modified OEM sump to increase capacity and windage flaps
    Cusco catch can
    HKS cam gears
    Microtech LT10s
    SQ Engineering COP plate
    1zz coils
    Trust oil cooler and remote oil filter including thermostat control
    T3 underdrive water pump pulley
    TRD oil filter
    TRD thermostat
    TRD radiator cap
    52mm alloy radiator
    Silicone radiator hoses
    Drivetrain:
    JDM t50
    TRD short shifter
    extreme 4 puk clutch
    T series disc diff
    Unknown ratio and centre, very tight LSD (will pull apart one day)
    Suspension front:
    AE86 strut converted to coilover by AJPS
    AJPS 7kg springs
    HTS102 front inserts
    Cusco camber top
    Cusco lower control arms Formula link
    Cusco castor rods
    Cusco cross brace
    Cusco 23mm swaybar
    AJPS RCA
    AJPS lock spacer
    AJPS rack bushes
    Powersteering arms
    New rack ends and boots supplied by AJPS
    rear:
    4.5kg rear springs
    HTS102 adjustable shocks
    Cusco on car adjustable panhard rod
    AJPS traction brackets
    complete rebushing
    Brakes:
    FC3s rx7 calipers
    unknown brand adaptor
    AJPS braided brake lines
    AJPS S13 rear rotor conversion
    r32 master cylinder, custom brake lines made by me
    interior:
    stripped plastics and carpet
    Bride fixed back seat "HKS edition"
    Bride recliner passenger seat
    autometer tacho
    autometer boost
    autometer oil pressure
    autometer oil temp
    autometer coolant temp
    wheels
    R: 15 x 8.5 -22 Work Equip 03
    F: 15 x 8.0 -4 Superlites
  1. 4agte turbo steup,ae86 shell,ae86 7oint bolt in cage and more
    By _wanna-be_ in forum Car Parts For Sale
    Last Post: 12th December 2012, 06:11 AM
  2. Huws slow as shit 86 build 4AGZE
    By slide86 in forum AE86 Owners Forums
    Last Post: 16th September 2008, 01:17 AM
