Results 1 to 7 of 7
Thread: 4AC Cooling
    Ross
    Default 4AC Cooling
    So I thought I would post here in hope someone could help me out as I am rather confused
    Last week, driving along, nothing big just the usual 2,000RPM shifts and suddenly the temperature guage jumps to the hottest setting. Engine over heated and started dripping coolant. Managed to get it home all safe though.
    First thing I thought was check the thermostat, however I can't find one at all. From looking at the engine I could only guess is was in the bottom water housing. Is this right?
    I only ask this as I cannot find the thermostat at all in the bottom water housing. I find this odd as the engine has been holding its temperature great up till just last week. Is this possible or am I missing something obvious?
    Cheers Fusion
    Alex
    Wagga Wagga
    Head gasket blow? Oil doesn't look like a milkshake does it?
    Alex's 4AGTE KE70
    Or so was thought...
    Ross
    Will double check the oil, cheers
    But still wondering about the thermostat, I thought it would of had one for sure with how its been running
    Site Supporter Javal's Avatar
    Josho
    Why would you check the thermostat first? You wouldn't.
    First - check your coolant level
    Second - find your coolant leak if it is low
    Third - fix it. Make sure engine reaches operating temperature, no air in the system and that the thermostat is opening.
    Fourth - if symptoms persist, check temperature difference across radiator.
    That's about as hard as troubleshooting a 4AC cooling system gets.
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    if the coolant is leaking find the leak then seal it when you fill it up again make sure you bleed all the air out thouroghly it makes a big difference
    Ross
    Ah Javal I had checked all those. Should of pointed that out. Coolant pretty much went pretty quickly. I checked the thermostat first as it seemed odd for it to suddenly happen, when I knew it had been going great up till than.
    I am going to reseal it all, get the radiator checked out, buy new hoses and actually install a thermostat, because as far as I can see . . . the car never came with a thermostat from the old owner.
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    The thermostat is in the inlet housing. It would be weird for it to suddenly do it if it has never had one installed, as it would probably always do that. It might have failed, or the radiator might have a problem (I'm guessing), so its good that you're getting it checked.
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
  1. hooking up 4ac cooling system
    By easyvision in forum Technical - Questions
    Last Post: 29th September 2012, 10:54 AM
  2. 4ac Cooling System Parts (Good Condition)
    By easyvision in forum Cars or Parts Wanted
    Last Post: 25th July 2012, 11:23 PM
  3. 4ac cooling issues..
    By ae86a in forum Technical - Questions
    Last Post: 18th May 2009, 05:23 PM
  4. GZE Cooling
    By hugh in forum Technical - Questions
    Last Post: 20th March 2009, 09:52 PM
  5. cooling question
    By YAZE in forum Technical - Questions
    Last Post: 3rd October 2008, 11:50 PM
