Results 1 to 5 of 5
Thread: NEED HELP WITH STARTER!!!!!!!!!!!!!
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    Default NEED HELP WITH STARTER!!!!!!!!!!!!!
    Hi all
    Would somebody be able to help me out with this problem...
    My hachi has had a Link installed by previous owner, and left a mess of cables in the engine bay so...
    I was doing some tidying-up of cables over the weekend, it started then i put it all back together to find out it doesnt want to go
    The relay for the starter motor gets 12V on the two 'control' pins (85 & 86) of the relay when you turn the key to start position
    the two pins to the starter circuit (30 & 87a) also get 12V but nothing happens, the relay 'clicks' but starter doesnt go
    theres another relay for the fan which works perfectly fine, so im sure its wired up alright
    any help will be very much appreciated!
ID:	33587   Click image for larger version.
ID:	33588   Click image for larger version.
ID:	33589   Click image for larger version.
ID:	33590   Click image for larger version.
ID:	33592   Click image for larger version.
ID:	33593   Click image for larger version.
ID:	33594   Click image for larger version.
ID:	33595   Click image for larger version.
ID:	33597   Click image for larger version.
ID:	33598   Click image for larger version.
ID:	33599   Click image for larger version.
ID:	33600   Click image for larger version.
ID:	33602   Click image for larger version.
ID:	33603   Click image for larger version.
ID:	33604   Click image for larger version.
ID:	33605   Click image for larger version.
ID:	33607   Click image for larger version.
ID:	33608   Click image for larger version.
    check to see you didn't disconnect the power to the starter solenoid, and that your earth is still connected to the relay
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    Theres one big cable that runs from the starter to the alternator (I think) and another that runs to a fuse box and to the relay... but theres another small cable that runs from the relay to somewhere... is it supposed to go to the little square plug by the positive pin on the starter??
    Trace the cable from the small plug on the starter backwards. My bet is it isn't connected.
    Pin 87 is the pin that should goto the starter
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    All sorted guys,
    Had to wire the cable from the relay to another cable that plugged directly into the small pin on the starter. It looks like there must've been a fault in the circuit at some point and someone manually wired up another circuit?? seems quite dodgy.
    Thanks for help
  1. 4agze starter
    By ca18ae71 in forum Cars or Parts Wanted
    Last Post: 10th January 2010, 02:22 PM
  2. starter motor
    By ae86rally in forum Technical - Questions
    Last Post: 2nd September 2009, 12:33 PM
  3. Need help with starter motor
    By hugh in forum Technical - Questions
    Last Post: 19th September 2008, 07:34 PM
  4. Starter Motor
    By ae71neo in forum Cars or Parts Wanted
    Last Post: 2nd July 2008, 05:03 PM
  5. Starter motor
    By Beserker99 in forum Technical - Questions
    Last Post: 31st December 2005, 08:49 PM
