Results 1 to 9 of 9
Thread: 20V Silvertop turbo to N/A
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    Default 20V Silvertop turbo to N/A
ID:	33799Click image for larger version.
ID:	33800Click image for larger version.
ID:	33801Click image for larger version.
ID:	33802Click image for larger version.
ID:	33803Click image for larger version.
ID:	33804Click image for larger version.
ID:	33805Click image for larger version.
ID:	33806Click image for larger version.
ID:	33807Click image for larger version.
ID:	33808Click image for larger version.
ID:	33809Click image for larger version.
ID:	33810Click image for larger version.
ID:	33811Click image for larger version.
ID:	33812Click image for larger version.
ID:	33813Click image for larger version.
ID:	33814Click image for larger version.
    Car is currently 20V ST turbo with Link G4 Storm, Master Power turbo ITB's, W55 box hilux lsd
    swapping out for stock standard ST, will put as many bits as I can from the current engine including flywheel, blocking plates for the water galleries, injectors etc.
    Questions:
    What injectors should I run on new set up, 440cc or standard?
    Any special plumbing need to be done under the throttles?
    thoughts?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Standard injectors can supply heaps of fuel for non turbo use unless you plan on running an alcahol fuel.
    No special plumbing is needed, where you refering to the water system?
    can you explain more what this is - "Master Power turbo ITB's" ?
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    Thanks for your reply Sam
    Master power turbo (comma) ITB'S
    haha
    Just saying, the ITB's were left in for the turbo set up.
    Mt Macedon
    If you'll still be running the Link ECU, then run the injectors from the turbo engine. Less need for a retune then.
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    Thanks for your reply, wouldn't the ignition timing for the new tune be way different anyway?
    Mt Macedon
    Ideally, no. If you use MAP for load, then the NA engine will just use part of the load table, never reaching the bit above atmospheric pressure. If it was tuned well, then this part will still be good (assuming same cams, compression, fuel etc). However there was probably little time spent optimising the timing off boost at high RPM, and whenever you make big changes it's always smart to get your tune checked and adjusted.
    Endeavour Hills
    pjcp01: I thought it might of been the name of aftermarket mod to the throttle bodies, the Malaysians seem to love names like that.
    Hen: totally off topic- it's good to still have you around on here, it sure has been a while for us two now.
    Mar 2013
    andrew
    perth
    offtopic.
    but are you going to swap out the trans and diff for lighter items ?
    Oct 2014
    Patrick
    auckland
    Auckland
    New Zealand
    Hmmm.... there isn't a MAP sensor to be found but there is a sensor on the inlet plenum that looks like an air temp sensor of some sort, apparently I won't need it. Am planning to have it tuned anyway.
  1. silvertop turbo parts, NSW
    By dtour in forum Car Parts For Sale
    Last Post: 17th January 2014, 10:53 AM
  2. [PERTH] 20v Silvertop with ECU and loom, other 20v things for sale.
    By quadeyquade in forum Car Parts For Sale
    Last Post: 12th August 2012, 10:00 PM
  3. VIC: Silvertop 20v TURBO Bottomend! Full Balance, ACL Forgies
    By Sprinter86 in forum Car Parts For Sale
    Last Post: 18th January 2011, 12:24 AM
  4. 20v turbo manifold, T25 turbo, seats, momo wheel
    By twin_cam in forum Car Parts For Sale
    Last Post: 30th May 2010, 01:21 PM
  5. silvertop 20v or blacktop 20v
    By Cj_sullivan in forum General Topics (No Technical Questions)
    Last Post: 6th September 2006, 12:42 PM
