Results 1 to 7 of 7
Thread: Valve spring options for ST20v with stock cams
    tye
    nsw
    wollongong
    Default Valve spring options for ST20v with stock cams
    Howdy,
    I've tried searching various forums and google with no avail and was hoping some cluey people could enlighten me.
    Following the template...
    Car - AE86
    motor / part in question - Silvertop 20v valve springs for stock cams
    problem - I am in the middle of changing out worn valve stem seals and thought I would measure the springs. There are variations of a few mm's + from neighbouring springs so I thought while I am here it would be worth putting in fresh springs. I am struggling to find information on the spring specs and tolerences for running stock cams and was hoping that I could get some advice on what valve springs I should run with stock cams and if it is anything else that would be worth changing while I've got it apart. Any links would to either tech or products would be greatly appreciated.
    personal situation (if applicable)- I was considering upgrading cams/cam gears as the engine that came with the car was rebuilt with some JE pistons and lightened/balanced crank but was a bit scared of the breaking in process. I would consider manning up if I could find a decent person/workshop around wollongong to break them in, ect.
    Cheers all.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Running new cams in doesn't involve anything more than putting some moly lube on them when you fit them, and holding the engine at roughly 2000rpm for 5-10 minutes. Cam choice will depend on what pistons you have though, as the extra compression height can cause issues with piston to valve clearance. Worth finding out, or like you said taking it to someone who has built quite a few 20v's.
    Moderator Frak's Avatar
    Jamie
    Default Valve springs
    Toda Racing are easy to get and quite cheap.
    Hachiroku since 1994
    tye
    nsw
    wollongong
    Ah right cheers for the reply James, I was reading kelfords articles on the website about degreeing the cam and thought it's probably something I don't want to just give a crack haha.
    Yeah thats what I am not sure about Jamie, are the toda/supertech/kelford ect suited to stock cams or are their specs more suited towards angrier cams? I have emailed Kelford but no replies.
    Cheers,
    Tye
    Jamie
    Toda will work fine with std camshafts.
    tye
    nsw
    wollongong
    Cheers mate!
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have Supertech Springs and genuine stem seals in stock, if you are interested send me a PM.
  1. 20 valve cams, valve springs, (and the third lobe touching...)
    By Jonny Rochester in forum Technical - Articles
    Last Post: 30th August 2010, 12:02 AM
  2. Engine Build - Valve Options - Bearing Options - Head Gasket
    By hitoriko in forum Technical - Questions
    Last Post: 19th September 2009, 05:59 PM
  3. Valve spring compressors
    By Mickey H in forum Tool Talk
    Last Post: 2nd May 2009, 02:30 PM
  4. KE70 front spring options
    By lilslvrrolla in forum Technical - Questions
    Last Post: 9th July 2008, 11:46 AM
  5. Valve Spring Upgrades
    By in forum General Topics (No Technical Questions)
    Last Post: 1st January 1970, 11:00 AM
