Results 1 to 4 of 4
Thread: Is 20V CAS Signal the same as 4AGZE CAS Signal?
    Mar 2011
    Ali
    Default Is 20V CAS Signal the same as 4AGZE CAS Signal?
    Car - KE70 with 20V
    Motor / part in question - New engine build - 16V 4AGZE
    Problem - Old microtech configured to 20V CAS/Dizzy
    Did a search and trolled through some old posts, but didn't really find a clear answer.
    As above, what is the difference between 20V CAS and the 16V GZE CAS?
    - I'm not on about the cap and rotor button assembly, I mean wires and signals for ignition for ECU.
    Will 16V GZE CAS wire straight up to ECU configured for 20V CAS, or is an internal modification required to make it work?
    Ali
    Mar 2011
    Ali
    No one?
    Jun 2013
    Johan
    Notrh-West
    Klerksdorp
    South-Africa
    The signal should be the same as both have a multi tooth wheel and a cam angle sensor. You will have to check the wiring and connect them the right way to get your ne and g pickups wired correctly. I am sure your Microtech will work
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  1. 4agze CAS signal problems with Haltech e8
    By lloydious86 in forum Technical - Questions
    Last Post: 4th October 2009, 06:22 PM
  2. 4agze CAS
    By sundee in forum Cars or Parts Wanted
    Last Post: 20th June 2009, 10:33 PM
  3. wtb: ae101 20v tps plug and ae92 4agze CAS plug
    By 84ae86coupe in forum Cars or Parts Wanted
    Last Post: 26th September 2008, 05:24 PM
  4. How to get a speed signal??20v silvertop
    By D0R186 in forum Technical - Questions
    Last Post: 25th December 2007, 04:31 PM
