so postage only? keen...
Sent from my SM-G900I using Tapatalk
Selling my old Turbo setup from my 4AGTE, will suit 4AGE or 4AGZE motors.
The turbo is off a Nissan Skyline RB20 motor, it made 128kw atw on my tired old motor at 14psi. Would say it’s capable of 140kw tops.
Comes with Turbo, my old slightly ugly yet functional T3 manifold and dump pipe. Turbo seems to be in good working order, had it out on a couple of track days with no issues.
Would suit someone looking for a cheap setup to go from 4AGE or 4AZGE to turbo.
Asking price $300 for the lot, will post anywhere in AU at buyers expense.
You mean is it postage only? If you are in Brissy can arrange pickup if you like.
Postage would work out cheap as well, should be around $25 to anywhere in AU by TNT courier.
Still available? What ECU did you run this with?
Yep still have it all mate. It was run on an EMS stinger 4424 v2 which ran it fine.
You would have to double check, but if you have a stock gze AFM ecu you might be able to get away with running it off that. The stock injectors should be able to handle 130kw.
