Results 1 to 4 of 4
Thread: 4agze water plumbing?
    Apr 2014
    anthony
    nsw
    north sydney
    Default 4agze water plumbing?
    Hi guys I have a 4age blue top in RWD setup, I'm thinking of changing to ae101 gze would like to know if the RWD water plumbing is the same?
    And are there many other things that need to be done to convert a 4agze to RWD.
    Thanks
    Mt Macedon
    Factory RWD Water setup won't work on a 4AGZE (purely from what I've heard and seen on the net) as the thermostat and outlet from the head foul on the SC. You can use the normal FWD remote thermostat housing and FWD pump and head outlet. You'll need to modify the pipes running along the engine, but there are about 1000 writeups on how to do that.
    Other bits are:
    - a spacer so you can flip the intake pipe leading to the throttle
    - modifying SC outlet pipe and inlet manifold for a front mount
    - mounting coils somewhere
    - maybe moving the alternator to clear the swaybar (can be an issue in AE86s, but sounds like you've got a Datsun anyway)
    Again there are a bunch of writeups with way more detail floating round the net.
    Bryan
    Waterford
    Tramore
    Ireland
    Using the parts you should have with the 4A-GZE you will be able to do the following:
    You cut the water pump suction pipe in 1/2 and reuse it below the S/C bracket, you will need to add the 8mm throttle body coolant pipes to suit.
    Apr 2014
    anthony
    nsw
    north sydney
    Thanks guys helps heaps.
    There is so much info on here! should try and get one all ready converted haha
  1. 4agze water piping.
    By 86TRD in forum Technical - Questions
    Last Post: 13th May 2010, 02:08 PM
  2. turbo water and oil plumbing
    By slidn_ways in forum Technical - Questions
    Last Post: 30th May 2008, 07:56 PM
  3. 4AGZE water pump
    By nelpd96 in forum Technical - Questions
    Last Post: 5th November 2007, 11:57 AM
  4. 4agze water pumps ?
    By samuek in forum Technical - Questions
    Last Post: 25th July 2007, 02:05 PM
  5. [BNE] RWD Water pump & plumbing
    By PuGZoR in forum Cars or Parts Wanted
    Last Post: 2nd July 2007, 11:06 AM
